[GRASS-dev] git: how to avoid bogus merge commits
Even Rouault even.rouault at spatialys.com
Wed May 22 12:44:22 PDT 2019
On mercredi 22 mai 2019 21:30:58 CEST Markus Metz wrote:
> Hi git gurus,
> when I modify my local copy and do git commit + git push, I sometimes get
> an error:
> "failed to push some refs"
> and a hint:
> "Updates were rejected because the remote contains work that you do not
> have locally. This is usually caused by another repository pushing to the
> same ref. You may want to first integrate the remote changes (e.g., 'git
> pull ...') before pushing again."
> OK, I do "git pull" and get confronted with a merge commit message.
You may do
git fetch origin  (assuming 'origin' point to OSGeo/grass)
git rebase origin/master
git push
this will rebase your local commit(s) on top of latest upstream repo
Even
http://www.spatialys.com
