[GRASS-dev] [GRASS GIS] #3852: PyGRASS GridModule silently ignores when module has no output defined
GRASS GIS trac at osgeo.org
Fri May 24 05:35:24 PDT 2019
 Reporter:  martinl      |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  normal       |  Milestone:  7.6.2
Component:  PyGRASS      |    Version:  unspecified
 Keywords:  GridModule   |        CPU:  Unspecified
 Platform:  Unspecified  |
 For modules like G7:r.mapcalc PyGRASS !GridModule class fails to work. No
 output is patched since the module has no output option defined.
 from grass.pygrass.modules import Module
 from grass.pygrass.modules.grid import GridModule
 from grass.pygrass.utils import findmaps
 from grass.pygrass.gis import Mapset
 Module('g.region', n=1000, s=0, e=1000, w=0, res=1)
 grd = GridModule('r.mapcalc',
                  width=250, height=250, overlap=0,
                  processes=4, split=False,
                  expression='out = 1')
 grd.run()
 print (findmaps('raster', 'out', mapset=str(Mapset())))
 Prints
  100%
  100%
  100%
  100%
  100%
  100%
  100%
  100%
  100%
  100%
  100%
  100%
  100%
  100%
  100%
  100%
 -> no raster map created. The !GridModule should fail at least when no
 output option is defined.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3852>
