[GRASS-dev] Forestfrag WARNING: ZSTD compression error -14: Unsupported frame parameter
Paulo van Breugel p.vanbreugel at gmail.com
Tue May 28 09:25:55 PDT 2019
On Tue, May 28, 2019 at 5:30 PM Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Mon, May 27, 2019 at 3:25 PM Paulo van Breugel <p.vanbreugel at gmail.com>
> wrote:
>> Hi Václav / devs
>> I am running r.forestfrag in Windows 10, grass 7.6.2 Computation with a
>> moving window size of 21 (but at another computer same happens at size 9)
>> gives met the following error:
>> C:\Users\brp\AppData\Roaming\GRASS7\addons/scripts/r.forestfrag.py
>> input=groenreclass at landschap output=AAtest7 size=21
>> Step 1: Computing Pf values...
>> Step 2: Computing Pff values...
> Some computations happened, but then something went wrong.
It goes wrong when with the moving window computation using r.mapcalc. But
when (e.g., with what moving window size) differs depending on the computer
and the size of the raster.
>> ERROR: Error uncompressing raster data for row 328 of
>> <tmpA04_398bad3c_32a8_4220_8566_374c8c9f16a8>
> Something wrong with the libraries or the files (perhaps not enough space
> on disk?).
I guess something with the files, as it works with smaller moving windows
and it works in Linux.
>> WARNING: No data base element files found
> Probably, g.remove trying to clean something as the the script is exiting.
> Likely harmless.
Ah, ok
>> Traceback (most recent call last):
>>   File "C:\Users\brp\AppData\Roaming\GRASS7\addons/scripts/
>> r.forestfrag.py", line 420, in <module>     sys.exit(main(*gs.parser()))
>> r.forestfrag.py", line 290, in main     ipl=ipl, tmpl4=expr1,
>> tmpl5=expr2, pff=pff)
>>   File
>> "C:\OSGEO4~1\apps\grass\grass76\etc\python\grass\script\raster.py", line
>> 111, in mapcalc " with expression: %s") % e)
>>   File "C:\OSGEO4~1\apps\grass\grass76\etc\python\grass\script\core.py",
>> line 667, in fatal error(msg)
>> line 651, in error    message(msg, flag='e')
>> line 584, in message     run_command("g.message", flags=flag, message=msg,
>> errors='ignore')
> Here, it is g.message failing, so at this point nothing works.
>> line 415, in run_command ps = start_command(*args, **kwargs)
>> line 382, in start_command
>>     return Popen(args, **popts)
>> line 76, in __init__     subprocess.Popen.__init__(self, args, **kwargs)
>>   File "C:\OSGEO4~1\apps\Python27\lib\subprocess.py", line 390, in
>> __init__ errread, errwrite)
>>   File "C:\OSGEO4~1\apps\Python27\lib\subprocess.py", line 640, in
>> _execute_child startupinfo)
>> WindowsError: [Error 206] De bestandsnaam of -extensie is te lang
> Too many open files? Or maybe just the error message happens to be too
> long.
>> Any idea what may be the problem here?
> Try smaller region, smaller window. Look into task manager. ...
I did try a smaller region, this does seem to make a difference. I will try
if I can do this more systematically.
> Best,
> Vaclav
>> Greetings,
>> Paulo
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190528/ae394f7c/attachment-0001.html>
