[GRASS-dev] upcoming winGRASS 7.8.1 with gdal3 and proj6
Helmut Kudrnovsky hellik at web.de
Tue Nov 5 14:44:24 PST 2019
hi devs,
see
http://osgeo-org.1560.x6.nabble.com/WinGRASS-build-up-WIP-tp5420766p5421066.html
upcoming winGRASS 7.8.1 will be out with gdal3 and proj6:
GRASS is now configured for:  x86_64-w64-mingw32
  Source directory:           /usr/src/rc_nexgen/grass-7.8.1RC1
  Build directory:            /usr/src/rc_nexgen/grass-7.8.1RC1
  Installation directory:     ${prefix}/grass78
  Startup script in directory:/c/OSGeo4W64/bin
  C compiler:                 gcc -g -O2
  C++ compiler:               c++ -g -O2
  Building shared libraries:  yes
  OpenGL platform:            Windows
  MacOSX application:         no
  MacOSX architectures:
  MacOSX SDK:
  BLAS support:               no
  BZIP2 support:              yes
  C++ support:                yes
  Cairo support:              yes
  DWG support:                no
  FFTW support:               yes
  FreeType support:           yes
  GDAL support:               yes
  GEOS support:               yes
  LAPACK support:             no
  Large File support (LFS):   yes
  libLAS support:             yes
  MySQL support:              no
  NetCDF support:             no
  NLS support:                yes
  ODBC support:               yes
  OGR support:                yes
  OpenCL support:             no
  OpenGL support:             yes
  OpenMP support:             no
  PDAL support:               no
  PNG support:                yes
  POSIX thread support:       no
  PostgreSQL support:         yes
  Readline support:           no
  Regex support:              yes
  SQLite support:             yes
  TIFF support:               yes
  X11 support:                no
  Zstandard support:          yes
  using new PROJ 5+ API <=
GRASS GIS 7.8.1RC1 exported compilation log
Started compilation: Tue Nov  5 22:20:43 CET 2019
Errors in:
No errors detected.
Finished compilation: Tue Nov  5 23:04:48 CET 2019
System Info
GRASS Version: 7.8.1RC1
Code revision: exported
Build date: 2019-11-05
Build platform: x86_64-w64-mingw32
GDAL: 3.0.2    <=
PROJ: 6.2.1     <=
GEOS: 3.8.0
SQLite: 3.29.0
Python: 3.7.0
wxPython: 4.0.3
Platform: Windows-10-10.0.18362-SP0 (OSGeo4W)
great work!
please test in the OSGeo4W framework with the Exp. tick activated.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
