[GRASS-dev] PROJ6 support in GRASS
Even Rouault
even.rouault at spatialys.com
Thu Nov 7 11:04:56 PST 2019
On jeudi 7 novembre 2019 19:50:33 CET Markus Metz wrote:
> On Thu, Nov 7, 2019 at 6:47 PM Martin Landa <landa.martin at gmail.com> wrote:
> > Hi,
> > čt 7. 11. 2019 v 15:17 odesílatel Markus Metz
> > <markus.metz.giswork at gmail.com> napsal:
> > > PROJ 6 support is not yet finished in GRASS. Currently it sort of works
> in master and relbr78, but I expect troubles because GRASS is heavily
> relying on deprecated proj strings as CRS definitions. This is becoming
> problematic e.g. when creating locations from GDAL/OGR datasets because
> GRASS goes from OGR spatialreference through proj string to GRASS
> definition.
> > OSGeo4W packages are planned to be switched to GDAL3/PROJ6 soon, are
> > you aware of any known bugs?
> yes, EPSG:3857 is causing trouble. This is the WGS 84 / Pseudo-Mercator
> projection on a sphere with radius 6378137 that needs special treatment
> which no longer works with GRASS + PROJ 6 + GDAL 3.
> g.proj epsg=3857 -p gives me
> -PROJ_INFO-------------------------------------------------
> name : WGS 84 / Pseudo-Mercator
> datum : wgs84
> ellps : wgs84
> proj : merc
> lat_ts : 0
> lon_0 : 0
> x_0 : 0
> y_0 : 0
> k : 1
> wktext : defined
> no_defs : defined
> -PROJ_EPSG-------------------------------------------------
> epsg : 3857
> -PROJ_UNITS------------------------------------------------
> unit : meter
> units : meters
> meters : 1
> which is wrong because it should be a Mercator projection on a sphere, not
> an ellipsoid
Well, this is a messy topic. EPSG:3857 uses the WebMercator projection, which
is not the standard Mercator projection since it uses spherical formulas even
if the datum and ellipsoid is WGS84
So neither proj=merc + ellps=wgs84 or proj=merc + ellps=sphere are
technically correct
Nothing new with PROJ 6 for that case
> projinfo -o PROJ EPSG:3857
> gives me
> PROJ.4 string:
> +proj=merc +a=6378137 +b=6378137 +lat_ts=0 +lon_0=0 +x_0=0 +y_0=0 +k=1
> +units=m +nadgrids=@null +wktext +no_defs +type=crs
Yes, this is a hack of PROJ.4 still supported by PROJ 6 to more or less get
the correct result of WebMercator using the standard Mercator, by lying on the
ellipsoid definition (using the Sphere) and applying a nadgrids=null, so that
no datum transformation between WGS84 and that Sphere is attempted !
> that is correct, but unfortunately not returned by GDAL's function
> OSRExportToProj4() which is now deprecated.
Hum, I do ot agree with this. This *is* still what is returned by GDAL
OSRExportToProj4() with GDAL + PROJ master :
$ gdalsrsinfo EPSG:3857
PROJ.4 : +proj=merc +a=6378137 +b=6378137 +lat_ts=0 +lon_0=0 +x_0=0 +y_0=0
+k=1 +units=m +nadgrids=@null +wktext +no_defs
And you also actually use (PROJ 6 required here)
$ gdalsrsinfo "+proj=webmerc +datum=WGS84"
(or $ projinfo "+proj=webmerc +datum=WGS84 +type=crs" -o PROJ )
> That means GRASS needs to avoid
> OSRExportToProj4() with GDAL 3+:
In the general case, I agree with your conclusion, but not for the above one
http://www.spatialys.com
