[GRASS-dev] [GRASS-user] WinGRASS build up (WIP)
    Helmut Kudrnovsky
    hellik at web.de
    Thu Nov 14 11:29:23 PST 2019
Helmut Kudrnovsky wrote
> Pedro Venâncio-2 wrote
>> Hi Markus and Markus,
>> I hope someone else can test, because here in my machine:
>> - GRASS 7.8.1 standalone 64bits does not work;
>> - GRASS 7.8.0 standalone 64bits work fine;
>> - GRASS 7.8.1 from OSGeo4W64 does not work, also inside QGIS;
>> - GRASS 7.8.0 from OSGeo4W64 does not work, also inside QGIS;
>> - GRASS 7.8.1 installed with QGIS 3.4.13-2 and QGIS 3.10.0-2 does not
>> work,
>> also inside QGIS;
>> - GRASS 7.6.1 installed with QGIS 3.4.13-1 and QGIS 3.10.0-1 work fine,
>> alone and inside QGIS.
>> In all of them, when I try to run any GRASS algorithm from grass78
>> --text,
>> I get the gdal300.dll error.
> now testing standalone installer
> (http://download.osgeo.org/osgeo4w/osgeo4w-setup-x86_64.exe):
> Starting GRASS GIS...
> WARNUNG: Sperren gleichzeitiger Zugriffe auf ein Mapset ist unter Windows
>          nicht möglich.
> Cleaning up temporary files...
>           __________  ___   __________    _______________
>          / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
>         / / __/ /_/ / /| | \__ \\_  \   / / __ / / \__ \
>        / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
>        \____/_/ |_/_/  |_/____/____/   \____/___//____/
> Welcome to GRASS GIS 7.8.1
> GRASS GIS homepage:                      https://grass.osgeo.org
> This version running through:            Command Prompt
> (C:\WINDOWS\system32\cmd.exe)
> Help is available with the command:      g.manual -i
> See the licence terms with:              g.version -c
> See citation options with:               g.version -x
> If required, restart the GUI with:       g.gui wxpython
> When ready to quit enter:                exit
> Launching
> <wxpython>
>  GUI in the background, please wait...
> Microsoft Windows [Version 10.0.18362.449]
> (c) 2019 Microsoft Corporation. Alle Rechte vorbehalten.
> C:\Users\hkmyr>g.version --help
> Displays GRASS GIS version info.
> Benutzung:
>  g.version [-cxbreg] [--help] [--verbose] [--quiet] [--ui]
> Schalter:
>   -c   Gebe auch die Copyright-Informationen aus
>   -x   Print also the citation options
>   -b   Print also the build information
>   -r   Print also the GIS library revision number and date
>   -e   Print also extended info for additional libraries
>   -g   Print info in shell script style (including Git reference commit)
> C:\Users\hkmyr>g.version -breg
> version=7.8.1
> date=2019
> revision=c865432c9
> build_date=2019-11-10
> build_platform=x86_64-w64-mingw32
> build_off_t_size=8
>  ./configure  --host=x86_64-w64-mingw32 '--with-libs=C:\OS3944~1/lib'
> --with-includes=/c/OSGeo4W64/include --libexecdir=/c/OSGeo4W64/bin
> --prefix=/c/OSGeo4W64/apps/grass --bindir=/c/OSGeo4W64/bin
> --includedir=/c/OSGeo4W64/include --without-x --with-cxx --enable-shared
> --enable-largefile --with-fftw --with-freetype
> --with-freetype-includes=/mingw64/include/freetype2
> --with-proj-share=/c/OSGeo4W64/share/proj
> --with-proj-includes=/c/OSGeo4W64/include
> --with-proj-libs=/usr/src/grass781/mswindows/osgeo4w/lib --with-postgres
> --with-postgres-includes=/c/OSGeo4W64/include
> --with-postgres-libs=/usr/src/grass781/mswindows/osgeo4w/lib
> --with-gdal=/usr/src/grass781/mswindows/osgeo4w/gdal-config
> --with-geos=/usr/src/grass781/mswindows/osgeo4w/geos-config --with-sqlite
> --with-sqlite-includes=/c/OSGeo4W64/include
> --with-sqlite-libs=/usr/src/grass781/mswindows/osgeo4w/lib --with-regex
> --with-nls --with-zstd --with-odbc --with-cairo --with-opengl=windows
> --with-bzlib
> --with-liblas=/usr/src/grass781/mswindows/osgeo4w/liblas-config
> libgis_revision=00000
> libgis_date="?"
> proj=6.2.1
> gdal=3.0.2
> geos=3.8.0
> sqlite=3.29.0
> C:\Users\hkmyr>gdalinfo --version
> GDAL 3.0.2, released 2019/10/28
> C:\Users\hkmyr>r.slope.aspect --help
> Generates raster maps of slope, aspect, curvatures and partial derivatives
> from an elevation raster map.
> Benutzung:
>  r.slope.aspect [-aen] elevation=name [slope=name] [aspect=name]
>    [format=string] [precision=string] [pcurvature=name] [tcurvature=name]
>    [dx=name] [dy=name] [dxx=name] [dyy=name] [dxy=name] [zscale=value]
>    [min_slope=value] [--overwrite] [--help] [--verbose] [--quiet] [--ui]
> Schalter:
>   -a   Do not align the current region to the raster elevation map
>   -e   Compute output at edges and near NULL values
>   -n   Create aspect as degrees clockwise from North (azimuth), with flat
> -9999
> C:\Users\hkmyr>v.dissolve --help
> Löst Grenzen zwischen benachbarten Flächen mit gleicher Kategorienummer
> oder
> gleichem Attributwert auf.
> Benutzung:
>  v.dissolve.py input=name [layer=string] [column=name] output=name
> Parameter:
>    input   Name der Eingabe-Vektorkarte
>    layer   Layer number or name.
>             Standard: 1
>   column   Name of attribute column used to dissolve common boundaries
>   output   Name der Ausgabe-Vektorkarte
> also winGRASS7.8.1 64 bit standalone is starting and working here.
tested standalone with
System Info
GRASS Version: 7.8.1
Code revision: c865432c9
Build date: 2019-11-10
Build platform: x86_64-w64-mingw32
GDAL: 3.0.2
PROJ: 6.2.1
GEOS: 3.8.0
SQLite: 3.29.0
Python: 3.7.0
wxPython: 4.0.3
Platform: Windows-10-10.0.18362-SP0
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
