[GRASS-dev] [GRASS GIS] #3947: v.in.ascii: add second warning about import of files without category column
GRASS GIS trac at osgeo.org
Sat Nov 16 21:29:20 PST 2019
column
 Reporter:  jidanni      |      Owner:  grass-dev@…
     Type:  enhancement  |     Status:  new
 Priority:  trivial      |  Milestone:
Component:  Docs         |    Version:  unspecified
 Keywords:               |        CPU:  Unspecified
 Platform:  Unspecified  |
 On man v.in.ascii after
  Import of files without category column If the input file does not
 contain a category column, there is the possibility to auto-generate these
 IDs (categories). To automatically add an additional column named 'cat',
 the cat parameter must be set to the virtual column number 0 (cat=0). This
 is the default action if the cat parameter is not set.
 add an additional warning that these will be **unique** categories. In
 fact: 1, 2, 3...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3947>
