[GRASS-dev] [GRASS GIS] #3949: Number examples
GRASS GIS trac at osgeo.org
Sat Nov 16 21:35:09 PST 2019
 Reporter:  jidanni      |      Owner:  grass-dev@…
     Type:  enhancement  |     Status:  new
 Priority:  minor        |  Milestone:
Component:  Docs         |    Version:  unspecified
 Keywords:               |        CPU:  Unspecified
 Platform:  Unspecified  |
 $ w3m -dump file:///usr/share/doc/grass-doc/html/v.segment.html | grep
 ^Example
 Example: Extract line segment from 400m to 5000m from beginning of line 1:
 Example: Create parallel 1km long line segments along first 8km of track,
 Example: A series of points, spaced every 2km along the tracks
 Example: A series of points, spaced every 2km along the tracks, offset
 500m to
 Example: A series of points, spaced every 10% of the line's length along
 the
 These should be called Example 1, Example 2, etc. with their own Table
 of Contents entries too.
 In fact just like is already implemented on v.in.ascii.html !
Ticket URL: <https://trac.osgeo.org/grass/ticket/3949>
