[GRASS-dev] [GRASS GIS] #3951: v.in.ascii: add: Note: z= always still needs to be set manually, despite using -z.
trac at osgeo.org
Sat Nov 16 21:44:41 PST 2019
using -z.
Reporter: jidanni | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: trivial | Milestone:
Component: Docs | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
In v.in.ascii at
z=integer
Number of column used as z coordinate (points mode)
First column is 1. If 0, z coordinate is not used
Default: 0
add:
In fact perhaps 3 would be a good default, if -z use is detected...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3951>
