[GRASS-dev] [GRASS GIS] #3960: v.to.points: clarify user is not able to control where points end up
GRASS GIS trac at osgeo.org
Sat Nov 16 22:33:15 PST 2019
 Reporter:  jidanni      |      Owner:  grass-dev@…
     Type:  enhancement  |     Status:  new
 Priority:  trivial      |  Milestone:
Component:  Docs         |    Version:  unspecified
 Keywords:               |        CPU:  Unspecified
 Platform:  Unspecified  |
 In man v.to.points at
  "The dmax parameter is the maximum limit but not an exact distance."
 then do mention
  "A complicated internal algorithm is used to place points at certain
 points best representing the line."
 before saying
  "To place points with exact distance from the beginning of the vector
 line the user should use v.segment."
 That way the user would finally understand that he is not able to control
 the exact distances where points end up, and stop trying. In fact it would
 be good to say that to!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3960>
