[GRASS-dev] [GRASS GIS] #3962: GRASS 7.8.1 GUI doesn't run on Pop! OS 18.04 (Ubuntu 18.04) because of "ImportError: cannot import name 'NewIdRef'"
GRASS GIS trac at osgeo.org
Sun Nov 17 06:41:00 PST 2019
 Reporter:  rorschach  |      Owner:  grass-dev@…
     Type:  defect     |     Status:  new
 Priority:  normal     |  Milestone:  7.8.2
Component:  wxGUI      |    Version:  git-releasebranch78
 Keywords:             |        CPU:  x86-64
 Platform:  Linux      |
 Hi everyone,
 I installed GRASS 7.8.1 via the ubuntugis-unstable repository on my
 machine running Pop! OS 18.04 (based on Ubuntu 18.04). When I run GRASS,
 this error occurs:
 Starting GRASS GIS...
   File "/usr/lib/grass78/gui/wxpython/gis_set.py", line 43, in <module>
     from startup.guiutils import SetSessionMapset, NewMapsetDialog
   File "/usr/lib/grass78/gui/wxpython/startup/guiutils.py", line 25, in
 <module>
     from gui_core.dialogs import TextEntryDialog
   File "/usr/lib/grass78/gui/wxpython/gui_core/dialogs.py", line 50, in
 <module>
     from gui_core.gselect import LocationSelect, MapsetSelect, Select, \
   File "/usr/lib/grass78/gui/wxpython/gui_core/gselect.py", line 64, in
 <module>
     from gui_core.widgets import ManageSettingsWidget,
 CoordinatesValidator
   File "/usr/lib/grass78/gui/wxpython/gui_core/widgets.py", line 92, in
 <module>
     from gui_core.wrap import Button, SearchCtrl, StaticText, StaticBox, \
   File "/usr/lib/grass78/gui/wxpython/gui_core/wrap.py", line 39, in
 <module>
     from wx import NewIdRef as NewId
 ERROR: Error in GUI startup. See messages above (if any) and if necessary,
 please report this error to the GRASS developers.
 On systems with package manager, make sure you have the right GUI package,
 probably named grass-gui, installed.
 To run GRASS GIS in text mode use the --text flag.
 Use '--help' for further options
      grass78 --help
 See also: https://grass.osgeo.org/grass78/manuals/helptext.html
 Exiting...
 I checked the module in question (wx). The said module isn't available on
 the default Python (python2) of my machine.
 Python 2.7.15+ (default, Oct  7 2019, 17:39:04)
 [GCC 7.4.0] on linux2
 Type "help", "copyright", "credits" or "license" for more information.
 >>> import wx
   File "<stdin>", line 1, in <module>
 ImportError: No module named wx
 It is however available on my machine's Python 3.
 Python 3.6.8 (default, Oct  7 2019, 12:59:55)
 [GCC 8.3.0] on linux
 >>> import wx
 >>> wx.__version__
 '4.0.1'
 When I try to import NewIdRef, it doesn't exist but NewId does.
 >>> import wx
 Finally, GRASS text mode works. It really is just the GUI that fails.
 Thanks everyone!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3962>
