[GRASS-dev] [GRASS GIS] #3978: r.kappa: Segmentation fault
trac at osgeo.org
Wed Nov 20 12:14:22 PST 2019
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.2
Component: Imagery | Version: svn-trunk
Resolution: | Keywords: r.kappa
CPU: Unspecified | Platform: Linux
Comment (by hellik):
tested with in the GUI
System Info
GRASS version: 7.8.1
Code revision: c865432c9
Build date: 2019-11-10
Build platform: x86_64-w64-mingw32
GDAL: 3.0.2
PROJ: 6.2.1
GEOS: 3.8.0
SQLite: 3.29.0
Python: 3.7.0
wxPython: 4.0.3
Platform: Windows-10-10.0.18362-SP0 (OSGeo4W)
r.kappa -w classification=landuse96_28m at PERMANENT
reference=landclass96 at PERMANENT
ACCURACY ASSESSMENT
21:12:55 2019
MASK: none
MAPS: MAP1 = South-West Wake county: Simplified landuse classes
(landclass96 at PERMANENT in PERMANENT)
MAP2 = South-West Wake county: NC Land Use 1996 clipped
(landuse96_28m at PERMANENT in PERMANENT)
Error Matrix
Panel #1 of 2
MAP1
cat# 1 2 3 4 5 6 7 8
9
M 1 34931 38146 0 0 0 0 0 0
0
A 2 0 0 2137 0 0 0 0 0
0
P 3 0 0 0 25488 0 30 0 0
0
2 4 0 0 0 0 0 0 16464
320 45
5 0 0 0 0 0 0 0 0
0
6 0 0 0 0 0 0 0 0
0
7 0 0 0 0 0 0 0 0
0
8 0 0 0 0 0 0 0 0
0
9 0 0 0 0 0 0 0 0
0
10 0 0 0 0 0 0 0 0
0
11 0 0 0 0 0 0 0 0
0
15 0 0 0 0 0 0 0 0
0
18 0 0 0 0 0 0 0 0
0
20 0 0 0 0 0 0 0 0
0
21 0 0 0 0 0 0 0 0
0
Col Sum 34931 38146 2137 25488 0 30 16464
320 45
Panel #2 of 2
MAP1
cat# 10 11 15 18 20 21 Row Sum
M 1 0 0 0 0 0 0 73077
A 2 0 0 0 0 0 0 2137
P 3 0 0 0 0 0 0 25518
2 4 0 0 0 0 0 0 16829
5 7893 19733 64774 33865 0 0 126265
6 0 0 0 0 5303 0 5303
7 0 0 0 0 0 194 194
8 0 0 0 0 0 0 0
9 0 0 0 0 0 0 0
10 0 0 0 0 0 0 0
11 0 0 0 0 0 0 0
15 0 0 0 0 0 0 0
18 0 0 0 0 0 0 0
20 0 0 0 0 0 0 0
21 0 0 0 0 0 0 0
Col Sum 7893 19733 64774 33865 5303 194 249323
Cats % Commission % Ommission Estimated Kappa
1 52.199735 0.000000 0.392953
2 100.000000 100.000000 -0.180635
3 100.000000 100.000000 -0.008645
4 100.000000 100.000000 -0.113870
5 NA NA NA
6 100.000000 100.000000 -0.000120
7 100.000000 100.000000 -0.070704
8 NA NA NA
9 NA NA NA
10 NA NA NA
11 NA NA NA
15 NA NA NA
18 NA NA NA
20 NA NA NA
21 NA NA NA
Kappa Kappa Variance
0.094648 0.000001
Obs Correct Total Obs % Observed Correct
34931 249323 14.010340
MAP1 Category Description
1: developed
2: agriculture
3: herbaceous
4: shrubland
5: forest
6: water
7: sediment
8: (no description)
9: (no description)
10: (no description)
11: (no description)
15: (no description)
18: (no description)
20: (no description)
21: (no description)
MAP2 Category Description
1: High Intensity Developed
2: Low Intensity Developed
3: Cultivated
4: Managed Herbaceous Cover
5: Upland Herbaceous
6: Riverine/Estuarine Herbaceous
7: Evergreen Shrubland
8: Deciduous Shrubland
9: Mixed Shrubland
10: Mixed Hardwoods
11: Bottomland Hardwoods/Hardwood Swamps
15: Southern Yellow Pine
18: Mixed Hardwoods/Conifers
20: Water Bodies
21: Unconsolidated Sediment
(Wed Nov 20 21:12:55 2019) Command finished (0 sec)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3978#comment:2>
