[GRASS-dev] [GRASS GIS] #3979: G79: problem with i.sentinel.import and importer.write_metadata()
Stefan Blumentrath Stefan.Blumentrath at nina.no
Wed Nov 20 14:06:57 PST 2019
Sorry, I am on it.
Fra: grass-dev <grass-dev-bounces at lists.osgeo.org> på vegne av GRASS GIS <trac at osgeo.org>
Sendt: onsdag 20. november 2019 22:19
Kopi: grass-dev at lists.osgeo.org <grass-dev at lists.osgeo.org>
Emne: [GRASS-dev] [GRASS GIS] #3979: G79: problem with i.sentinel.import and importer.write_metadata()
 Reporter:  neteler                              |      Owner:  grass-dev@…
     Type:  defect                               |     Status:  new
 Priority:  normal                               |  Milestone:
Component:  Imagery                              |    Version:  svn-trunk
 Keywords:  i.sentinel.import, image             |        CPU:  Unspecified
  collections                                    |
 Platform:  Unspecified                          |
 I was trying to import Sentinel-2 (S2-L1C) data into G78 in order to make
 use of image collections:
 i.sentinel.import input=/mnt/geodata/openeo_bolzano/
 register_output=s2_t_register.csv
 Processing <T32TPS_20180608T101021_B02>...
 Importing raster map <T32TPS_20180608T101021_B02>...
  100%
 Processing <T32TPS_20180608T101021_B12>...
 Importing raster map <T32TPS_20180608T101021_B12>...
  100%
 Processing <T32TPS_20180608T101021_B07>...
 Importing raster map <T32TPS_20180608T101021_B07>...
  100%
 Processing <T32TPS_20180608T101021_B11>...
 Importing raster map <T32TPS_20180608T101021_B11>...
  100%
 Processing <T32TPS_20180608T101021_B10>...
 Importing raster map <T32TPS_20180608T101021_B10>...
  100%
 Processing <T32TPS_20180608T101021_B03>...
 Importing raster map <T32TPS_20180608T101021_B03>...
  100%
 Writing metadata to maps...
   File "/root/.grass7/addons/scripts/i.sentinel.import", line 504, in
 <module>
     sys.exit(main())
   File "/root/.grass7/addons/scripts/i.sentinel.import", line 488, in main
   File "/root/.grass7/addons/scripts/i.sentinel.import", line 407, in
 write_metadata
     meta = ip_meta[ip]
 KeyError: 'S2B_MSIL1C_20180613T101019_N0206_R022_T32TPS_20180613T122213'
 I am using a rasther fresh version:
 g.version -rge
 version=7.9.dev
 date=2019
 revision=exported
 build_date=2019-11-19
 build_platform=x86_64-pc-linux-gnu
 build_off_t_size=8
 libgis_revision=00000
 libgis_date="?"
 proj=4.9.3
 gdal=2.2.3
 geos=3.6.2
 sqlite=3.22.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/3979>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20191120/a0c9694e/attachment-0001.html>
