[GRASS-dev] [GRASS GIS] #3979: G79: problem with i.sentinel.import and importer.write_metadata()
trac at osgeo.org
Thu Nov 21 02:22:14 PST 2019
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Imagery | Version: svn-trunk
Resolution: | Keywords: i.sentinel.import, image
CPU: | collections
Unspecified | Platform: Unspecified
Comment (by sbl):
That`s odd indeed. I cannot reproduce the error with exactly the same
scene and both trunk and 7.8 on Fedora 30.
With an older version of trunk:
g.version -rge
version=7.9.dev
date=2019
revision=400349708
build_date=2019-08-31
build_platform=x86_64-pc-linux-gnu
build_off_t_size=8
libgis_revision=00000
libgis_date="?"
proj4=5.2.0
gdal=2.3.2
geos=3.7.1
sqlite=3.26.0
as well as a fresh compiled one and 7.8.1:
g.version -rge
version=7.8.1RC1
date=2019
revision=exported
build_date=2019-11-11
build_platform=x86_64-redhat-linux-gnu
build_off_t_size=8
libgis_date="?"
proj=5.2.0
gdal=2.3.2
geos=3.7.1
sqlite=3.26.0
I have no issues with i.sentinel.import with that scene.
Maybe the download was not 100% OK?
Do you have other scenes in that directory?
BTW, does 7.8 support band references?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3979#comment:4>
