[GRASS-dev] [GRASS GIS] #3979: G79: problem with i.sentinel.import and importer.write_metadata()
trac at osgeo.org
Thu Nov 21 13:12:52 PST 2019
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Imagery | Version: svn-trunk
Resolution: | Keywords: i.sentinel.import, image
CPU: | collections
Unspecified | Platform: Unspecified
Comment (by neteler):
Replying to [comment:8 sbl]:
> Hm, I think I have a hunch. Can you try to
> 1) delete all SAFE directories (or use a different unzip dir)
> 2) run i.sentinel.import again and see if the error remains?
Bingo! Now it ran through, finally.
> If you don`t link (l-flag) the unpacked SAFE dirs should actually be
removed automatically...
I didn't use -l this time.
> If they are present, i.sentinel.import does not unpack again (anymore
after my changes). If an import is interrupted it may lead to issues like
yours...
I see. May I suggest that, if present, the SAFE directory be actually
removed before unpacking? Less confusion :-)
Rationale: it may happen then a `i.sentinel.import` job is interrupted, be
by the user, for disk-full reasons or whatever else might occur...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3979#comment:9>
