[GRASS-dev] [GRASS GIS] #3940: Error Reading settings from Roaming file
GRASS GIS trac at osgeo.org
Wed Nov 27 11:09:44 PST 2019
  Reporter:  dnewcomb  |      Owner:  grass-dev@…
      Type:  defect    |     Status:  new
  Priority:  normal    |  Milestone:  7.8.2
 Component:  wxGUI     |    Version:  git-releasebranch78
Resolution:            |   Keywords:  Error Reading Settings
       CPU:  x86-64    |   Platform:  MSWindows
Comment (by hellik):
 confirmed, tested here:
 System Info
 GRASS version: 7.8.1
 Code revision: c865432c9
 Build date: 2019-11-10
 Build platform: x86_64-w64-mingw32
 GDAL: 3.0.2
 PROJ: 6.2.1
 GEOS: 3.8.0
 SQLite: 3.29.0
 Python: 3.7.0
 wxPython: 4.0.3
 Platform: Windows-10-10.0.18362-SP0 (OSGeo4W)
 here it is a win 10 box with german locale; when I switch in the GRASS
 preferences to english as GUI language; after restarting I get the same
 following message:
 Starting GRASS GIS...
 Error: Reading settings from file
 <C:\Users\myuser\AppData\Roaming\GRASS7\wx> failed.
                 Details: not enough values to unpack (expected 2, got 1)
                 Line: ''
 WARNING: Concurrent mapset locking is not supported on Windows
 Cleaning up temporary files...
           __________  ___   __________    _______________
          / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
         / / __/ /_/ / /| | \__ \\_  \   / / __ / / \__ \
        / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
        \____/_/ |_/_/  |_/____/____/   \____/___//____/
 Welcome to GRASS GIS 7.8.1
 GRASS GIS homepage:                      https://grass.osgeo.org
 This version running through:            Command Prompt
 (C:\WINDOWS\system32\cmd.exe)
 Help is available with the command:      g.manual -i
 See the licence terms with:              g.version -c
 See citation options with:               g.version -x
 If required, restart the GUI with:       g.gui wxpython
 When ready to quit enter:                exit
 Launching <wxpython> GUI in the background, please wait...
 Microsoft Windows [Version 10.0.18363.476]
 (c) 2019 Microsoft Corporation. Alle Rechte vorbehalten.
 C:\>Error: Reading settings from file
                 Line: ''
Ticket URL: <https://trac.osgeo.org/grass/ticket/3940#comment:3>
