[GRASS-dev] Python scripts: trigger cleanup function at keyboard interrupt (CTRL-C)
Moritz Lennert
mlennert at club.worldonline.be
Mon Oct 14 08:04:48 PDT 2019
On 14/10/19 16:44, Anna Petrášová wrote:
> This is used in many scripts and should work:
> https://grasswiki.osgeo.org/wiki/GRASS_Python_Scripting_Library#Sophisticated_cleanup_procedure
Not sure this works on a Ctrl-C. ISTR it doesn't, but this would have to
be verified.
Moritz
> On Mon, Oct 14, 2019 at 10:00 AM Markus Neteler <neteler at osgeo.org
> <mailto:neteler at osgeo.org>> wrote:
> Hi,
> in the GRASS GIS 6 shell scripts we used this code to clean up temp
> files upon CTRL-C signal:
> cleanup()
> g.message -v "Cleaning up ..."
> cd "$MSET_DIR"
> rm -rf "$TMP_DIR"
> #### trap ctrl-c so that we can clean up tmp
> trap 'cleanup' 2 3 15
> If there anything similar we could add to the python scripts?
> thanks
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/grass-dev
