[GRASS-dev] r.mapcalc does not overwrite the MASK raster map under Windows
Nikos Alexandris
nik at nikosalexandris.net
Thu Oct 24 14:48:02 PDT 2019
Dears,
before submitting another ticket, can anyone test if, under Windows,
`r.mapcalc` does overwrite the 'MASK' raster map?
Speaking in Python,
EQUATION = "{result} = {expression}"
masking = "if( {spectrum} == {highest_quality_category} && "
masking += "{aggregation} == {category}, "
masking += "1, null() )"
# following:
# 'recreation_spectrum' is a raster map
# 'HIGHEST_RECREATION_CATEGORY' is an integer number
# 'aggregation' is another raster map
# 'category' is another integer number
masking = masking.format(
spectrum=recreation_spectrum,
highest_quality_category=HIGHEST_RECREATION_CATEGORY,
aggregation=aggregation,
category=category,
masking_equation = EQUATION.format(result="MASK", expression=masking)
grass.mapcalc(masking_equation, overwrite=True)
won't do under Windows. I yet have to verify this.
A workaround, currently:
g.remove( type="raster", name="MASK", flags='f')
See also:
https://gitlab.com/natcapes/r.estimap.recreation/commit/470be9d0f3a69f43a9b559c27c8864a324e49a68.
Nikos
