[GRASS-dev] [GRASS GIS] #3917: r.info|v.info|r3.info|t.info: display map size used on disk
GRASS GIS trac at osgeo.org
Sat Oct 26 13:18:02 PDT 2019
  Reporter:  neteler      |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:  7.8.1
 Component:  Default      |    Version:  svn-trunk
Resolution:               |   Keywords:  r.info, v.info, r3.info, t.info
       CPU:  All          |   Platform:  All
Comment (by mmetz):
 Regarding raster maps, a better place to report disk usage would be
 r.compress, because with r.compress you could test which compression
 method is most appropriate for your use case (trade-off between disk usage
 and IO speed).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3917#comment:3>
