[GRASS-dev] [GRASS GIS] #3927: r.external vs r.in.gdal under Windows
GRASS GIS trac at osgeo.org
Sat Oct 26 13:40:19 PDT 2019
  Reporter:  Nikos Alexandris  |      Owner:  grass-dev@…
      Type:  defect            |     Status:  new
  Priority:  critical          |  Milestone:
 Component:  Raster            |    Version:  svn-releasebranch76
Resolution:                    |   Keywords:  r.external, r.in.gdal
       CPU:  Unspecified       |   Platform:  MSWindows
Comment (by hellik):
 Replying to [comment:9 hellik]:
 > Replying to [comment:8 Nikos Alexandris]:
 > > Replying to [comment:2 hellik]:
 > > > System Info
 > > > GRASS Version: 7.6.1
 > > > GRASS SVN revision: r74292
 > > > Build date: 2019-03-19
 > > > Build platform: x86_64-w64-mingw32
 > > > GDAL: 2.4.0
 > > > PROJ.4: 5.2.0
 > > > GEOS: 3.7.0
 > > > SQLite: 3.26.0
 > > > Python: 2.7.14
 > > > wxPython: 2.8.12.1
 > > > Platform: Windows-10-10.0.18362 (OSGeo4W)
 > > Helmut, this is the result of a command, or did you handcraft-ed these
 lines by copy-pasting?
 > Nothing hand-crafted, just go to the wxgui -> systeminfo
 similar output by
 g.version -r -e -g
 version=7.8.1dev
 date=2019
 revision=4785a5b77
 build_date=2019-10-25
 build_platform=x86_64-w64-mingw32
 build_off_t_size=8
 libgis_revision=00000
 libgis_date="?"
 proj=5.2.0
 gdal=2.4.1
 geos=3.8.0
 sqlite=3.29.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/3927#comment:10>
