[GRASS-dev] [GRASS GIS] #3925: winGRASS 7.8.1dev: 'charmap' codec can't decode byte 0x9d - issue in vector attribute data handling (e.g. opening attribute table, v.report, etc)
GRASS GIS trac at osgeo.org
Sun Oct 27 13:12:33 PDT 2019
  Reporter:  hellik   |      Owner:  grass-dev@…
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  7.8.1
 Component:  Vector   |    Version:  git-releasebranch78
Resolution:           |   Keywords:  python3, py3, wingrass
       CPU:  x86-64   |   Platform:  MSWindows
Comment (by hellik):
 Replying to [comment:4 hellik]:
 > v.db.select output of the geonames data:
 > v.db.select map=at_geonames at data
 cat|geonameid|name|asciiname|alternatename|latitude|longitude|featureclass|featurecode|countrycode|cc2|admin1code|admin2code|admin3code|admin4code|population|elevation|gtopo30|timezone|modification
 1|2598245|Sandgatterl|Sandgatterl||47.75|14.56667|T|PASS|AT||04|415|41522||0||1490|Europe/Vienna|2014-05-02
 2|2598246|Viehtalalm|Viehtalalm||47.75|14.56667|L|GRAZ|AT||04||||0||1490|Europe/Vienna|1999-04-30
 3|2598247|Adlmoarstein|Adlmoarstein||47.75|14.55|T|CLF|AT||04||||0||1023|Europe/Vienna|1999-04-30
 4|2598248|Waldbaueralm|Waldbaueralm||47.75|14.56667|L|GRAZ|AT||04||||0||1490|Europe/Vienna|1999-04-30
 5|2598249|Federeck|Federeck||47.75|14.56667|T|PK|AT||04|415|41522||0||1490|Europe/Vienna|2014-05-02
 6|2598250|Mooshöhe|Mooshoehe||47.75|14.55|P|PPL|AT||04|415|41522||0||1023|Europe/Vienna|2014-05-02
 7|2598251|Antonihütte|Antonihuette||47.75|14.53333|S|HUT|AT||04|415|41522||0||866|Europe/Vienna|2014-05-02
 8|2598252|Bergeralm|Bergeralm||47.75|14.51667|L|GRAZ|AT||04||||0||780|Europe/Vienna|1999-04-30
 9|2598253|Blabergalm|Blabergalm||47.75|14.5|L|GRAZ|AT||04||||0||885|Europe/Vienna|1999-04-30
 10|2598254|Nattereck|Nattereck||47.75|14.48333|T|PK|AT||04|409|40914||0||721|Europe/Vienna|2014-05-02
 11|2598255|Langeck|Langeck||47.75|14.48333|T|PK|AT||04|409|40914||0||721|Europe/Vienna|2014-05-02
 12|2598256|Zorngraben|Zorngraben||47.75|14.46667|H|STMI|AT||04||||0||951|Europe/Vienna|1999-04-30
 13|2598257|Gugler|Gugler||47.75|14.45|T|PK|AT||04|409|40914||0||1019|Europe/Vienna|2014-05-02
 14|2598258|Zorngrabenklause|Zorngrabenklause||47.75|14.45|T|SLP|AT||04||||0||1019|Europe/Vienna|1999-04-30
 > 15|2598259|Sitzenbacher Klause|Sitzenbacher
 Klause||47.75|14.45|T|PK|AT||04|409|40914||0||1019|Europe/Vienna|2014-05-02
 16|2598260|Sitzenbachhütte|Sitzenbachhuette||47.75|14.45|S|HUT|AT||04|409|40914||0||1019|Europe/Vienna|2014-05-02
 17|2598261|Deckleitnerbach|Deckleitnerbach||47.75|14.45|H|STM|AT||04||||0||1019|Europe/Vienna|1999-04-30
 18|2598262|Hundseck|Hundseck||47.75|14.41667|T|PK|AT||04|409|40914||0||1120|Europe/Vienna|2014-05-02
 19|2598263|Schafgraben|Schafgraben||47.75|14.4|H|STMI|AT||04||||0||1081|Europe/Vienna|1999-04-30
 20|2598264|Maierreut|Maierreut||47.75|14.4|L|GRAZ|AT||04||||0||1081|Europe/Vienna|1999-04-30
 21|2598265|Rumpelmayrreut|Rumpelmayrreut||47.75|14.38333|L|GRAZ|AT||04||||0||1094|Europe/Vienna|1999-04-30
 22|2598266|Bloßboden|Blossboden||47.75|14.36667|T|SLP|AT||04||||0||1439|Europe/Vienna|1999-04-30
 > 23|2598267|Weiße Ries|Weisse
 Ries||47.75|14.36667|T|CLF|AT||04||||0||1439|Europe/Vienna|1999-04-30
 > v.db.select seems to work, but some encoding issues also there, e.g.
 **Weiße Ries|Weisse Ries**
 starting v.db.select pops up the same encoding error:
 Exception in thread Thread-20:
   File "C:\OSGEO4~1\apps\Python37\lib\threading.py", line
 917, in _bootstrap_inner
     self.run()
   File "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\core\gco
 nsole.py", line 162, in run
     self.resultQ.put((requestId, self.requestCmd.run()))
   File
 "C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\core\gcmd.py",
 line 606, in run
     self._redirect_stream()
   File
 line 631, in _redirect_stream
     line = recv_some(self.module, e=0, stderr=0)
   File
 line 335, in recv_some
     y.append(decode(r))
   File "C:\OSGEO4~1\apps\grass\grass78\etc\python\grass\scri
 pt\utils.py", line 193, in decode
     return bytes_.decode(enc)
   File "C:\OSGEO4~1\apps\Python37\lib\encodings\cp1252.py",
 line 15, in decode
     return
 codecs.charmap_decode(input,errors,decoding_table)
 UnicodeDecodeError: 'charmap' codec can't decode byte 0x9d
 in position 840: character maps to <undefined>
Ticket URL: <https://trac.osgeo.org/grass/ticket/3925#comment:5>
