[GRASS-dev] [GRASS GIS] #3917: r.info|v.info|r3.info|t.info: display map size used on disk
trac at osgeo.org
Sun Oct 27 14:09:13 PDT 2019
Reporter: neteler | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.8.1
Component: Default | Version: svn-trunk
Resolution: | Keywords: r.info, v.info, r3.info, t.info
CPU: All | Platform: All
Comment (by mmetz):
Thinking about it, r.info seems more appropriate.
In any case you should really use r.compress with different compression
methods to decide on the compression method appropriate for your needs.
r.compress also reports changes in disk usage when re-compressing.
Another easy way to estimate disk usage is the file size of the output of
`[r|v].pack -c`.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3917#comment:5>
