[GRASS-dev] [GRASS GIS] #3925: winGRASS 7.8.1dev: 'charmap' codec can't decode byte 0x9d - issue in vector attribute data handling (e.g. opening attribute table, v.report, etc)
trac at osgeo.org
Sun Oct 27 22:13:52 PDT 2019
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.8.1
Component: Vector | Version: git-releasebranch78
Resolution: | Keywords: python3, py3, wingrass
CPU: x86-64 | Platform: MSWindows
Comment (by neteler):
Replying to [comment:6 annakrat]:
> One practical way, which wouldn't solve this for all cases, but perhaps
majority is to have a new decode function for attribute data, which would
try first GRASS_DB_ENCODING if specified, then try decoding with local
encoding and if that doesn't work, use utf8.
Conditional GRASS_DB_ENCODING which might be used for inspiration in this
regards:
https://github.com/OSGeo/grass/blob/b5b00f972917e38a6a912f7c385ddbf791889e70/gui/wxpython/dbmgr/base.py#L971
Ticket URL: <https://trac.osgeo.org/grass/ticket/3925#comment:7>
