[GRASS-dev] i.fusion.hpf addon: observing strong range change
Markus Neteler neteler at osgeo.org
Mon Oct 28 04:33:44 PDT 2019
On Mon, Oct 28, 2019 at 10:46 AM Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> On 27/10/19 18:52, Markus Neteler wrote:
> > Hi,
> > I am using i.fusion.hpf on Worldview-2 data and see that the resulting
> > range is completely different:
> > # orig
> > r.info -r wv2_17OCT08182034_M2AS_058891334010_01_P001.5
> > min=0
> > max=1509
> > # HPF
> > r.info -r wv2_17OCT08182034_M2AS_058891334010_01_P001.5.hpf
> > min=-1045.79783524995
> > max=3416.06793724612
> Just guessing here, but did you try the -c flag ?
Now yes:
i.fusion.hpf pan=$PAN msx=$(g.list raster pattern="$COLORPREFIX.?"
sep=comma) -c --o
# band 8
r.info -r wv2_17OCT08182034_M2AS_058891334010_01_P001.8
min=0
max=1605
r.info -r wv2_17OCT08182034_M2AS_058891334010_01_P001.8.hpf
min=-1163.98434592277
max=3879.99538075697
So, -c doesn't seem to have any effect here.
Markus
