[GRASS-dev] [GRASS GIS] #3928: parser: --json bug with white space in parameter values
trac at osgeo.org
Mon Oct 28 09:45:49 PDT 2019
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.1
Component: LibGIS | Version: git-releasebranch78
Keywords: parser | CPU: Unspecified
Platform: Unspecified |
At time the JSON support stumbles over white space:
Consider:
GRASS 7.8.1dev (nc_spm_08):~ > v.db.update map=antenna_position
column='z_antenna' qcolumn='z + 2.00' --json
"module": "v.db.update",
"id": "v.db.update_1804289383",
"inputs":[
{"param": "map", "value": "antenna_position"},
{"param": "layer", "value": "1"},
{"param": "column", "value": "z_antenna"},
{"param": "query_column", "value": "z"}
The part ` + 2.00` does not survive...
The issue is somewhere in
https://github.com/OSGeo/grass/blob/master/lib/gis/parser_json.c
Ticket URL: <https://trac.osgeo.org/grass/ticket/3928>
