[GRASS-dev] [GRASS GIS] #3929: r.external vs r.in.gdal under Linux using r.his
GRASS GIS trac at osgeo.org
Thu Oct 31 13:30:43 PDT 2019
 Reporter:  Nikos Alexandris  |      Owner:  grass-dev@…
     Type:  defect            |     Status:  new
 Priority:  normal            |  Milestone:
Component:  Default           |    Version:  unspecified
 Keywords:  7.9.dev           |        CPU:  Unspecified
 Platform:  Linux             |
 Get sample raster maps from QGIS' repository
 wget
 'https://github.com/qgis/QGIS/blob/77725c90b8a5bfe61fde5097128cdf4fb3fce610/python/plugins/processing/tests/testdata/custom/grass7/float_raster.tif?raw=true'
 -O float_raster.tif
 wget
 'https://github.com/qgis/QGIS/blob/77725c90b8a5bfe61fde5097128cdf4fb3fce610/python/plugins/processing/tests/testdata/custom/grass7/raster_4class.tif?raw=true'
 -O raster_4class.tif
 wget
 'https://github.com/qgis/QGIS/blob/77725c90b8a5bfe61fde5097128cdf4fb3fce610/python/plugins/processing/tests/testdata/custom/grass7/raster_5class.tif?raw=true'
 -O raster_5class.tif
 # Import
 r.in.gdal in=raster_4class.tif out=raster_4class
 r.in.gdal in=raster_5class.tif out=raster_5class
 r.in.gdal input=float_raster.tif out=float_raster
 # Link to
 r.external in=raster_4class.tif out=raster_4class_ext
 r.external in=raster_5class.tif out=raster_5class_ext
 r.external input=float_raster.tif out=float_raster_ext
 # Query stats
 for MAP in float_raster float_raster_ext ;do echo $MAP; r.univar -g $MAP
 ;echo ;done
 for MAP in raster_4class raster_4class_ext ;do echo $MAP; r.univar -g $MAP
 ;echo ;done
 for MAP in raster_5class raster_5class_ext ;do echo $MAP; r.univar -g $MAP
 ;echo ;done
 As expected, the above commands return the same statistics for each pair
 of imported (`r.in.gdal`) and linked (`r.external`) map.
 # Convert (supposedly) to RGB
 r.his h=float_raster i=raster_4class s=raster_5class r=r g=g bl=b --o
 r.his h=float_raster_ext i=raster_4class_ext s=raster_5class_ext r=r_ext
 g=g_ext bl=b_ext --o
 # Query statistics
 for MAP in r r_ext ;do echo $MAP; r.univar -g $MAP ;echo ;done
 for MAP in g g_ext ;do echo $MAP; r.univar -g $MAP ;echo ;done
 for MAP in b b_ext ;do echo $MAP; r.univar -g $MAP ;echo ;done
 r
 n=14889
 null_cells=262
 cells=15151
 min=0
 max=252
 range=252
 mean=71.4881456108536
 mean_of_abs=71.4881456108536
 stddev=51.9267840636893
 variance=2696.39090319701
 coeff_var=72.6369157011754
 sum=1064387
 r_ext
 n=14889
 null_cells=262
 cells=15151
 min=125
 max=127
 range=2
 mean=125.927933373632
 mean_of_abs=125.927933373632
 stddev=0.76658997256503
 variance=0.587660186037254
 coeff_var=0.608752920839682
 sum=1874941
 g
 n=14889
 null_cells=262
 cells=15151
 min=0
 max=231
 range=231
 mean=95.9787091141111
 mean_of_abs=95.9787091141111
 stddev=61.6018003150434
 variance=3794.78180205448
 coeff_var=64.1827764549362
 sum=1429027
 g_ext
 n=14889
 null_cells=262
 cells=15151
 min=125
 max=127
 range=2
 sum=1874941
 b
 n=14889
 null_cells=262
 cells=15151
 min=0
 max=142
 range=142
 mean=83.9135603465646
 mean_of_abs=83.9135603465646
 stddev=46.9957861849984
 variance=2208.60391914608
 coeff_var=56.0049960827605
 sum=1249389
 b_ext
 n=14889
 null_cells=262
 cells=15151
 min=125
 max=127
 range=2
 sum=1874941
 Look at ranges only:
 for MAP in r r_ext ;do echo $MAP; r.info -r $MAP ;echo ;done
 r
 min=0
 max=252
 r_ext
 min=125
 max=127
 g
 min=0
 max=231
 g_ext
 min=125
 max=127
 b
 min=0
 max=142
 b_ext
 min=125
 max=127
 The above HIS to RGB conversion is NOT correct due to the necessity in
 `r.his` for 8-bit input maps.  Nevertheless, using the "same" input maps
 (i.e.:
   `float_raster` and `float_raster_ext`,
   `raster_4class` and `raster_5class`,
   `raster_4class_ext` and `raster_5class_ext`)
 should, in theory, deliver the same outputs (i.e.:
   `r r_ext`
   `g g_ext`
   `b b_ext`).
 Looking at the numbers, there is an unexpected (?) disagreement in the
 statistics between the pair of same map (one map imported, one map linked
 to via `r.external`).
 # With the current `r.his`, the right way to do this, would be:
 for MAP in \
     float_raster float_raster_ext \
     raster_4class raster_4class_ext \
     raster_5class raster_5class_ext ;do \
     r.rescale \
     in=$MAP \
     to=0,255 \
     out=${MAP}_8bit
 done
 Convert
 r.his h=float_raster_8bit i=raster_4class_8bit s=raster_5class_8bit
 r=r_8bit g=g_8bit bl=b_8bit
 r.his h=float_raster_ext_8bit i=raster_4class_ext_8bit
 s=raster_5class_ext_8bit r=r_ext_8bit g=g_ext_8bit bl=b_ext_8bit
 and check
 r_8bit
 n=14889
 null_cells=262
 cells=15151
 min=6
 max=250
 range=244
 mean=86.576331519914
 mean_of_abs=86.576331519914
 stddev=42.396468104142
 variance=1797.46050770553
 coeff_var=48.9700445373919
 sum=1289035
 r_ext_8bit
 n=14889
 null_cells=262
 cells=15151
 min=6
 max=250
 range=244
 sum=1289035
 g_8bit
 n=14889
 null_cells=262
 cells=15151
 min=1
 max=228
 range=227
 mean=102.257841359393
 mean_of_abs=102.257841359393
 stddev=47.2255504199476
 variance=2230.25261246701
 coeff_var=46.1828157060052
 sum=1522517
 g_ext_8bit
 n=14889
 null_cells=262
 cells=15151
 min=1
 max=228
 range=227
 sum=1522517
 b_8bit
 n=14889
 null_cells=262
 cells=15151
 min=5
 max=139
 range=134
 mean=94.0406340251192
 mean_of_abs=94.0406340251192
 stddev=38.318460482594
 variance=1468.30441375612
 coeff_var=40.7467058041726
 sum=1400171
 b_ext_8bit
 n=14889
 null_cells=262
 cells=15151
 min=5
 max=139
 range=134
 sum=1400171
 We suspect that something goes wrong with `r.external` and the range in
 input
 maps is not the same as when importing. This is not obvious at first.
 I.e., `r.info -r` reports identical ranges between
 imported and linked maps:
 for MAP in $(glr pattern=*raster* exclude=*8bit*) ;do echo $MAP; r.info -r
 $MAP ;echo ;done
 float_raster
 min=-303
 max=14847
 float_raster_ext
 min=-303
 max=14847
 raster_4class
 min=1
 max=4
 raster_4class_ext
 min=1
 max=4
 raster_5class
 min=1
 max=5
 raster_5class_ext
 min=1
 max=5
 obviously and expectedly, ranges are the same for maps rescaled to
 [0,255]:
 float_raster_8bit
 min=0
 max=255
 min=0
 max=255
 raster_4class_8bit
 min=0
 max=255
 min=0
 max=255
 raster_5class_8bit
 min=0
 max=255
 min=0
 max=255
 This came after looking at why the `r.his` related test in QGIS fails (see
 [https://travis-ci.org/qgis/QGIS/jobs/603479075#L3608]).
 1. The test itself there is not correct (as far as I understand, input
 maps must range in [0,255] for this test to be correct) but this is a
 different issue.
 2. The test fails after Panos' following PR
 [https://github.com/qgis/QGIS/pull/32425#].
 Panos and Nikos
Ticket URL: <https://trac.osgeo.org/grass/ticket/3929>
