[GRASS-dev] PROJ6 support in GRASS
Anna Petrášová kratochanna at gmail.com
Tue Sep 3 19:30:47 PDT 2019
On Tue, Sep 3, 2019 at 4:22 AM Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> Hi all,
> there is a new PR for PROJ6 support in GRASS
> https://github.com/OSGeo/grass/pull/118
> There are two important changes when using PROJ6:
> First, reprojection with v.proj and r.proj is no longer always possible
> without the user making informed decisions. The reason is that there can be
> several different operations available to reproject coordinates from one
> CRS to another CRS. These different operations are listed and the user has
> to provide the appropriate operation with the pipeline option, taking care
> of any axisswap.
first, thanks for all the work. Second, I don't see how most users are
supposed to know what to pick. Is there perhaps a way to pick a good
default? I just can't imagine not having r.import/v.import...
Anna
> Second, axis order is no longer always easting, northing, e.g. for
> EPSG:4326 it is northing, easting, and an axisswap might need to be removed
> from operations provided by PROJ.
> There are many more changes (see details in the PR), but these are the two
> most important ones.
> Feedback welcome!
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190903/19d17293/attachment.html>
