[GRASS-dev] winGRASS addons - consolidation/fix release needed!!
Martin Landa
landa.martin at gmail.com
Sat Sep 7 03:01:08 PDT 2019
so 7. 9. 2019 v 11:39 odesÃlatel Helmut Kudrnovsky <hellik at web.de> napsal:
> /usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/docs/html/pngdriver.html
> Fatal Python error: initfsencoding: unable to load the file system codec
> ModuleNotFoundError: No module named 'encodings'
this part I already solved locally. Will create WIP PR. I have
different problem with display dll.
I tried to run manually in msys2 bash:
GISRC=/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/demolocation/.grassrc79
GISBASE=C:/msys64/usr/src/grass79/dist.x86_64-w64-mingw32
PATH="/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/scripts:$PATH"
PYTHONPATH="C:/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/etc/python;C:/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/gui/wxpython;$PYTHONPATH"
PATH="/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/scripts:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/lib:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/lib:/c/OSGeo4W64/apps/Python37:/c/OSGeo4W64/bin:/c/msys64/usr/src/grass79/mswindows/osgeo4w/lib:/c/msys64/usr/src/grass79/mswindows/osgeo4w:/usr/bin:/mingw64/bin"
LC_ALL=C LANG=C LANGUAGE=C
/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin/d.barscale.exe
--html-description
I got no output, no error.
When I switched to r.info.exe, it works.
/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin/r.info.exe
--html-description
Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
