[GRASS-dev] winGRASS addons - consolidation/fix release needed!!
Helmut Kudrnovsky hellik at web.de
Sat Sep 7 03:20:35 PDT 2019
>it's not good idea to mix different version of Python.
it's not easy to keep msys2 and osgeo4w python in sync
>By [1] is
>forced osgeo4w Python version. In [2] he should remove all python
>packages.They are not needed.
does it mean that in msys2 there is no python3 needed at all?
pacman -S [...] mingw-w64-x86_64-python3-numpy mingw-w64-x86_64-python3-six
should this be removed von the how-to-compile wiki?
if I remember I added them when we started to compile with python3 back them
because compilation failed ....
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
