[GRASS-dev] winGRASS addons - consolidation/fix release needed!!
Helmut Kudrnovsky
hellik at web.de
Sat Sep 7 04:06:18 PDT 2019
Martin Landa wrote
> Hi,
> pá 30. 8. 2019 v 17:35 odesílatel Helmut Kudrnovsky <
> hellik@
> > napsal:
>> Do you have a list of your issues facing while winGRASS compiling?
> different ;-) I am closer to successful build. Now it fails compiling
> ctypes/display.py:
> Status: Processing description list.
> Traceback (most recent call last):
> File "./ctypesgen.py", line 165, in
> <module>
> ctypesgencore.processor.process(descriptions, options)
> File
> "C:\msys64\usr\src\grass79\lib\python\ctypes\ctypesgencore\processor\pipeline.py",
> line 60, in process
> find_source_libraries(data, options)
> File
> "C:\msys64\usr\src\grass79\lib\python\ctypes\ctypesgencore\processor\operations.py",
> line 206, in find_source_libraries
> library = ctypesgencore.libraryloader.load_library(library_name)
> File
> "C:\msys64\usr\src\grass79\lib\python\ctypes\ctypesgencore\libraryloader.py",
> line 258, in load_library
> result = LibraryLoader.load_library(self, libname)
> File
> line 63, in load_library
> return self.load(path)
> File
> line 279, in load
> return _WindowsLibrary(path)
> File
> line 240, in __init__
> self.cdll = ctypes.cdll.LoadLibrary(path)
> File "C:\OSGeo4W64\apps\Python37\lib\ctypes\__init__.py", line 434,
> in LoadLibrary
> return self._dlltype(name)
> File "C:\OSGeo4W64\apps\Python37\lib\ctypes\__init__.py", line 356,
> in __init__
> self._handle = _dlopen(self._name, mode)
> OSError: [WinError 127] Uvedená procedura nebyla nalezena
> make[6]: *** [Makefile:102: OBJ.x86_64-w64-mingw32/display.py] Error 1
I get a longer log with errors when I'm do make in the ctypes subfolder:
$ make
make
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib
make[1]: Entering directory
'/usr/src/grass_trunk_git/grass/lib/python/ctypes'
make[1]:
'/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib'
is up to date.
make[1]: Leaving directory
make OBJ.x86_64-w64-mingw32/date.py OBJ.x86_64-w64-mingw32/gis.py
OBJ.x86_64-w64-mingw32/raster.py OBJ.x86_64-w64-mingw32/gmath.py
OBJ.x86_64-w64-mingw32/proj.py OBJ.x86_64-w64-mingw32/imagery.py
OBJ.x86_64-w64-mingw32/vector.py OBJ.x86_64-w64-mingw32/rtree.py
OBJ.x86_64-w64-mingw32/display.py OBJ.x86_64-w64-mingw32/stats.py
OBJ.x86_64-w64-mingw32/dbmi.py OBJ.x86_64-w64-mingw32/raster3d.py
OBJ.x86_64-w64-mingw32/arraystats.py OBJ.x86_64-w64-mingw32/cluster.py
OBJ.x86_64-w64-mingw32/vedit.py OBJ.x86_64-w64-mingw32/segment.py
OBJ.x86_64-w64-mingw32/rowio.py OBJ.x86_64-w64-mingw32/temporal.py
OBJ.x86_64-w64-mingw32/ogsf.py OBJ.x86_64-w64-mingw32/nviz.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/date.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/gis.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/raster.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/gmath.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/proj.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/imagery.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/vector.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/rtree.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/display.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/stats.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/dbmi.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/raster3d.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/arraystats.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/cluster.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/vedit.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/segment.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/rowio.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/temporal.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/ogsf.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/nviz.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/__init__.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/ctypes_preamble.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/ctypes_loader.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/date.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/gis.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/raster.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/gmath.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/proj.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/imagery.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/vector.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/rtree.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/display.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/stats.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/dbmi.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/raster3d.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/arraystats.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/cluster.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/vedit.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/segment.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/rowio.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/temporal.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/ogsf.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/nviz.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/__init__.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/ctypes_preamble.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/ctypes_loader.pyc
make[1]: 'OBJ.x86_64-w64-mingw32/date.py' is up to date.
make[1]: 'OBJ.x86_64-w64-mingw32/gis.py' is up to date.
make[1]: 'OBJ.x86_64-w64-mingw32/raster.py' is up to date.
make[1]: 'OBJ.x86_64-w64-mingw32/gmath.py' is up to date.
make[1]: 'OBJ.x86_64-w64-mingw32/proj.py' is up to date.
make[1]: 'OBJ.x86_64-w64-mingw32/imagery.py' is up to date.
make[1]: 'OBJ.x86_64-w64-mingw32/vector.py' is up to date.
make[1]: 'OBJ.x86_64-w64-mingw32/rtree.py' is up to date.
GISRC=/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/demolocation/.grassrc79
GISBASE=C:/msys64/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32
PATH="/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/bin:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/bin:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/scripts:$PATH"
PYTHONPATH="C:/msys64/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python;C:/msys64/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/gui/wxpython;$PYTHONPATH"
PATH="/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/bin:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/bin:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/scripts:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/lib:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/lib:/mingw64/bin:/usr/local/bin:/usr/bin:/bin:/c/Windows/System32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0/:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl"
LC_ALL=C LANG=C LANGUAGE=C ./ctypesgen.py --cpp "gcc -E
-I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64
-I/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/include
-D__GLIBC_HAVE_LONG_LONG" -lgrass_display.7.9
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/include/grass/display.h
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/include/grass/defs/display.h
-o OBJ.x86_64-w64-mingw32/display.py
Status: Preprocessing C:/Users/hkmyr/AppData/Local/Temp/tmpr1ty7l93.h
Status: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64
-D__GLIBC_HAVE_LONG_LONG -U __GNUC__ -dD "-Dinline=" "-D__inline__="
"-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)="
"-D__asm(x)=" "-DCTYPESGEN=1"
"C:/Users/hkmyr/AppData/Local/Temp/tmpr1ty7l93.h"
Error: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64
-D__GLIBC_HAVE_LONG_LONG: In file included from
C:/msys64/mingw64/x86_64-w64-mingw32/include/_mingw.h:284,
-D__GLIBC_HAVE_LONG_LONG: from
C:/msys64/mingw64/x86_64-w64-mingw32/include/corecrt.h:10,
C:/msys64/mingw64/x86_64-w64-mingw32/include/crtdefs.h:10,
C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:9,
C:/msys64/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/include/grass/gis.h:24,
C:/msys64/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/include/grass/display.h:4,
C:/Users/hkmyr/AppData/Local/Temp/tmpr1ty7l93.h:1:
C:/msys64/mingw64/x86_64-w64-mingw32/include/vadefs.h:35:2: error: #error
VARARGS not implemented for this compiler
-D__GLIBC_HAVE_LONG_LONG: 35 | #error VARARGS not implemented for this
compiler
-D__GLIBC_HAVE_LONG_LONG: | ^~~~~
Status: Parsing C:/Users/hkmyr/AppData/Local/Temp/tmpr1ty7l93.h
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/corecrt.h:80: Syntax
error at 'uintptr_t'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:165: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:171: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:177: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:182: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:191: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:197: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:203: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:209: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:512: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:514: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:516: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:535: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:537: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:539: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:732: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:765: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:770: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:772: Syntax
error at ';'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:806: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:818: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:822: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:826: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:833: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:835: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:839: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:843: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1060: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1061: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1062: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1088: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1089: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1183: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1185: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1186: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1196: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1201: Syntax
error at 'argp'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1208: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1210: Syntax
error at ';'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1218: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:475:
Syntax error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:484:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:485:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:487:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:489:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:491:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:500:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:501:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:502:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:504:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:507:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:508:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:511:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:512:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:515:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:516:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:519:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:520:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:522:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:524:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:526:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:528:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:531:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:532:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:739:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:740:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:742:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:746:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:752:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:754:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:756:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:758:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:781:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:782:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:784:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:786:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:789:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:790:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:793:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:794:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:797:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:798:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:801:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:803:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:805:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:806:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/string_s.h:40:
Syntax error at ';'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/string_s.h:71:
Syntax error at ';'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/string_s.h:73:
Syntax error at ';'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/string_s.h:78:
Syntax error at '{'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/string_s.h:79:
Syntax error at ':'
Error:
C:/msys64/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/include/grass/defs/gis.h:157:
File "./ctypesgen.py", line 165, in <module>
File
"C:\msys64\usr\src\grass_trunk_git\grass\lib\python\ctypes\ctypesgencore\processor\pipeline.py",
line 60, in process
File
"C:\msys64\usr\src\grass_trunk_git\grass\lib\python\ctypes\ctypesgencore\processor\operations.py",
File
"C:\msys64\usr\src\grass_trunk_git\grass\lib\python\ctypes\ctypesgencore\libraryloader.py",
File
File
line 279, in load
File
File "C:/msys64/mingw64/lib/python3.7\ctypes\__init__.py", line 442, in
LoadLibrary
File "C:/msys64/mingw64/lib/python3.7\ctypes\__init__.py", line 364, in
__init__
OSError: [WinError 126] Das angegebene Modul wurde nicht gefunden
make[1]: *** [Makefile:102: OBJ.x86_64-w64-mingw32/display.py] Error 1
make: *** [Makefile:81: default] Error 2
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
