[GRASS-dev] winGRASS addons - consolidation/fix release needed!!
Helmut Kudrnovsky
hellik at web.de
Sat Sep 7 13:34:06 PDT 2019
Helmut Kudrnovsky wrote
> Martin Landa wrote
>> Hi,
>> so 7. 9. 2019 v 22:20 odesÃlatel Helmut Kudrnovsky <
>> hellik@
>> > napsal:
>>> in both test cases (d.barscale.exe --html-description, r.info.exe
>>> --html-description), I get nothing, neither an error message nor
>>> --html-description output.
>> strange, in the case of r.info.exe I am getting html description output.
> maybe too much linux/unix paths in windows world late at night ;-D
>>GISBASE=C:/msys64/usr/src/grass79/dist.x86_64-w64-mingw32
> is it really C:/ ? while all other paths are
> PATH="/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin:
what should go into $PATH? probably:
C:\msys64\usr\src\grass_trunk_git\grass\bin.x86_64-w64-mingw32
C:\msys64\usr\src\grass_trunk_git\grass\dist.x86_64-w64-mingw32
C:\msys64\usr\src\grass_trunk_git\grass\dist.x86_64-w64-mingw32\bin
C:\msys64\usr\src\grass_trunk_git\grass\dist.x86_64-w64-mingw32\lib
C:\msys64\usr\src\grass_trunk_git\grass\dist.x86_64-w64-mingw32\scripts
C:\msys64\usr\src\grass_trunk_git\grass\mswindows
C:\msys64\usr\src\grass_trunk_git\grass\mswindows\osgeo4w\lib
C:\OSGeo4W64\apps\Python37
C:\OSGeo4W64\bin
anything else?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
