[GRASS-dev] compilation grass 7.8 - GUI not started
    Paulo van Breugel
    p.vanbreugel at gmail.com
    Sat Sep 14 02:24:36 PDT 2019
Hi Devs
I just compiled/installed grass78 on my computer (Ubuntu 18.04). After
installation and starting grass, it opens the opening window to select
the database/location/mapset. After that, the GUI does not launch.
Error message on the command line copied below.
Any idea how to solve this, or is this a bug that I should report?
Cheers, Paulo
GRASS 7.8.1dev (exdet):~ > 11:21:16: Debug: Adding duplicate image
handler for 'Windows bitmap file'
11:21:16: Debug: Adding duplicate image handler for 'Windows bitmap file'
  File "/usr/local/grass78/grass78/gui/wxpython/wxgui.py", line 104, in OnInit
    from lmgr.frame import GMFrame
  File "/usr/local/grass78/grass78/gui/wxpython/lmgr/frame.py", line
51, in <module>
    from lmgr.layertree import LayerTree, LMIcons
  File "/usr/local/grass78/grass78/gui/wxpython/lmgr/layertree.py",
line 38, in <module>
    from mapdisp.frame import MapFrame
  File "/usr/local/grass78/grass78/gui/wxpython/mapdisp/frame.py",
line 33, in <module>
    from mapdisp.toolbars import MapToolbar, NvizIcons
  File "/usr/local/grass78/grass78/gui/wxpython/mapdisp/toolbars.py",
line 22, in <module>
    from nviz.main import haveNviz
  File "/usr/local/grass78/grass78/gui/wxpython/nviz/main.py", line
24, in <module>
    from nviz import mapwindow
  File "/usr/local/grass78/grass78/gui/wxpython/nviz/mapwindow.py",
line 42, in <module>
    from nviz.workspace import NvizSettings
  File "/usr/local/grass78/grass78/gui/wxpython/nviz/workspace.py",
line 23, in <module>
    from nviz import wxnviz
  File "/usr/local/grass78/grass78/gui/wxpython/nviz/wxnviz.py", line
52, in <module>
    from grass.lib.raster3d import *
  File "/usr/local/grass78/grass78/etc/python/grass/lib/raster3d.py",
line 1101, in <module>
    Rast3d_fatal_error = _variadic_function(_func,_restype,_argtypes)
TypeError: __init__() missing 1 required positional argument: 'errcheck'
OnInit returned false, exiting...
