[GRASS-dev] [GRASS GIS] #3909: Consistent variable names: r.import and r.proj
GRASS GIS trac at osgeo.org
Sun Sep 22 08:12:04 PDT 2019
 Reporter:  rshepard                         |      Owner:  grass-dev@…
     Type:  enhancement                      |     Status:  new
 Priority:  normal                           |  Milestone:  8.0.0
Component:  Projections/Datums               |    Version:  svn-trunk
 Keywords:  resample, method, interpolation  |        CPU:  x86-64
 Platform:  Linux                            |
 r.import has a an option called resample which defines the resampling
 method to use. r.proj has an option called method which defines the
 interpolation method to be used.
 Seems to me that resamplig == interpolation and I recommend changing the
 r.import veriable name from 'resample' to 'method' for consistency. After
 all, they list the same transformation types.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3909>
