[GRASS-dev] compilation grass 7.8 - GUI not started
Paulo van Breugel
p.vanbreugel at gmail.com
Mon Sep 23 02:47:50 PDT 2019
On Sun, Sep 22, 2019 at 6:57 PM Markus Neteler <neteler at osgeo.org> wrote:
> Hi Paulo,
> On Sat, Sep 14, 2019 at 11:24 AM Paulo van Breugel
> <p.vanbreugel at gmail.com> wrote:
> > Hi Devs
> > I just compiled/installed grass78 on my computer (Ubuntu 18.04). After
> > installation and
> just to be sure:
> - you compiled yourself?
Yes
> - you (of course) use Python 3?
Yes, it used to work when I was working in a virtual environment
(following the instructions on the wiki). Now I have set Python 3 as
the default.
> > starting grass, it opens the opening window to select
> > the database/location/mapset. After that, the GUI does not launch.
> > Error message on the command line copied below.
> > Any idea how to solve this, or is this a bug that I should report?
> > Cheers, Paulo
> > GRASS 7.8.1dev (exdet):~ > 11:21:16: Debug: Adding duplicate image
> > handler for 'Windows bitmap file'
> > 11:21:16: Debug: Adding duplicate image handler for 'Windows bitmap file'
> > Traceback (most recent call last):
> > File "/usr/local/grass78/grass78/gui/wxpython/wxgui.py", line 104, in OnInit
> > from lmgr.frame import GMFrame
> > File "/usr/local/grass78/grass78/gui/wxpython/lmgr/frame.py", line
> > 51, in <module>
> > from lmgr.layertree import LayerTree, LMIcons
> > File "/usr/local/grass78/grass78/gui/wxpython/lmgr/layertree.py",
> > line 38, in <module>
> > from mapdisp.frame import MapFrame
> > File "/usr/local/grass78/grass78/gui/wxpython/mapdisp/frame.py",
> > line 33, in <module>
> > from mapdisp.toolbars import MapToolbar, NvizIcons
> > File "/usr/local/grass78/grass78/gui/wxpython/mapdisp/toolbars.py",
> > line 22, in <module>
> > from nviz.main import haveNviz
> > File "/usr/local/grass78/grass78/gui/wxpython/nviz/main.py", line
> > 24, in <module>
> > from nviz import mapwindow
> > File "/usr/local/grass78/grass78/gui/wxpython/nviz/mapwindow.py",
> > line 42, in <module>
> > from nviz.workspace import NvizSettings
> > File "/usr/local/grass78/grass78/gui/wxpython/nviz/workspace.py",
> > line 23, in <module>
> > from nviz import wxnviz
> > File "/usr/local/grass78/grass78/gui/wxpython/nviz/wxnviz.py", line
> > 52, in <module>
> > from grass.lib.raster3d import *
> > File "/usr/local/grass78/grass78/etc/python/grass/lib/raster3d.py",
> > line 1101, in <module>
> > Rast3d_fatal_error = _variadic_function(_func,_restype,_argtypes)
> > TypeError: __init__() missing 1 required positional argument: 'errcheck'
> > OnInit returned false, exiting...
> Does this problem persist after
> make distclean
> and recompilation?
Yes, tried that both. But I'll give it another try after checking
manually for any residues.
> Markus
Thanks for the feedback
