[GRASS-dev] [GRASS GIS] #3618: v.distance: allow copying multiple attributes from nearest feature
GRASS GIS trac at osgeo.org
Wed Sep 25 10:50:38 PDT 2019
  Reporter:  sbl          |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  closed
  Priority:  normal       |  Milestone:  7.6.2
 Component:  Vector       |    Version:  unspecified
Resolution:  wontfix      |   Keywords:  v.distance
       CPU:  All          |   Platform:  All
Changes (by sbl):
 * status:  new => closed
 * resolution:   => wontfix
Comment:
 Of course, one can use the primary key of the to map in to_column and then
 run v.db.join. That is probably good enough...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3618#comment:3>
