[GRASS-dev] v.in.ogr Killed by Linux for saturating RAM+SWAP
Stefan Blumentrath Stefan.Blumentrath at nina.no
Mon Sep 30 05:25:02 PDT 2019
Hi Yann,
Did you try:
GRASS_VECTOR_LOWMEM
Environment variable?
See:
https://grass.osgeo.org/grass76/manuals/variables.html
Cheers
Stefan
From: grass-dev <grass-dev-bounces at lists.osgeo.org> On Behalf Of Yann Chemin
Sent: mandag 30. september 2019 14:17
To: GRASS-dev <grass-dev at lists.osgeo.org>
Subject: [GRASS-dev] v.in.ogr Killed by Linux for saturating RAM+SWAP
Hi devs,
I am trying to import a vector and it gets killed. Is there a direct way to let it not use the whole RAM+SWAP or should I get a bigger RAM system to do the manipulation ?
Thanks,
Yann
Importing 6146401 features (OGR layer <merged>)...
 100%
Registering primitives...
Cleaning polygons
Breaking polygons...
Breaking polygons (pass 1: select break points)...
 100%
Breaking polygons (pass 2: break at selected points)...
Killed
Dr. Yann Chemin
+33 7 83 85 5234
JRC, Ispra, IT
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190930/29d08efd/attachment.html>
