[GRASS-dev] [GRASS GIS] #504: wxGUI location wizard: set bounds by drawing a box on world map
trac at osgeo.org
Mon Aug 10 19:43:03 PDT 2020
Reporter: hamish | Owner: grass-dev@…
Type: enhancement | Status: closed
Priority: trivial | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
Resolution: wontfix | Keywords: location wizard
CPU: All | Platform: All
Changes (by wenzeslaus):
* status: new => closed
* resolution: => wontfix
Comment:
The bounding box/default region is now set automatically from a file or
not at all in the location wizard, so this does not really apply, so I'm
closing this now as won't fix.
However, now you can draw the region like this in the main GUI and there
is room for more some improvements regarding this own the New Startup
project is finished.
If there are other suggestions in context of the current state of things,
please open a new issue on !GitHub.
Ticket URL: <https://trac.osgeo.org/grass/ticket/504#comment:1>
