[GRASS-dev] [GRASS GIS] #2895: Define dependencies for GRASS addons
trac at osgeo.org
Tue Dec 29 02:02:03 PST 2020
Reporter: pmav99 | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.8.3
Component: Default | Version: unspecified
Resolution: | Keywords: g.extension
CPU: Unspecified | Platform: Unspecified
Comment (by sbl):
I just added a draft for a python script that could take care of
dependencies in Python (conda not tested) and R packages. Other
dependencies (e.g. C-libraries, commandline tools) are just checked,
neither loading of the libraries not installation is supported at the
moment (not sure if the latter is realistic).
The function has three modes: check (warns of missing dependencies),
install (installs missing dependencies (if possible), abort (stops if
dependencies are missing).
It takes the following arguments as input:
- dependency_type
- dependency
- version=None
- version_comparison=None
- repository=None
- optional=False
and could be fed e.g. from a table describing dependencies. dependency
versions, and specific repositories are not supported yet. Let me know
what you think, and i see how it could be integrated in g.extension.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2895#comment:23>
