[GRASS-dev] [GRASS GIS] #2424: PyGRASS does not work when GRASS is invoked from outside
trac at osgeo.org
Sun Feb 2 20:24:15 PST 2020
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.4
Component: Python | Version: svn-trunk
ctypes | Keywords: installation, pygrass, temporal,
Resolution: | scripts
CPU: | Platform: MSWindows 8
Unspecified |
Comment (by wenzeslaus):
Replying to [comment:16 martinl]:
> Still relevant?
Yes. As far as I know only thing which changed is having additional
workaround (besides explicit `LD_LIBRARY_PATH` or `--exec` and that is
installing `grass-session/grass_session` which is technically a 3rd party
package in that sense that it is not part of GRASS GIS.
Replying to [comment:17 sbl]:
> Here is a way to load PyGRASS libs in external Python:
> https://github.com/ninsbl/grass-
session/blob/grass_versions/grass_session/session.py#L305
> Not sure if this is what you are looking for?
Yes, `ctypes.CDLL(lib, mode=1)` looks like a way to address the issue. It
doesn't seem right to me that code to make GRASS GIS API work is outside
of GRASS GIS. Any ideas or opinions on having grass-session functionality
in GRASS GIS? Perhaps even avoiding the need for grass-session?
> Have not tested on Windows either...
Yes, that's a big concern here because `LD_LIBRARY_PATH`-like solution is
not practical there (and setting `GRASSBIN` is not either) and then there
is the issue of multiple Pythons and where or how to install grass-session
(which is actually not limited to Windows).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2424#comment:18>
