[GRASS-dev] Cairo driver does not render vector maps in PNG
Nikos Alexandris nik at nikosalexandris.net
Fri Feb 7 02:28:21 PST 2020
Recently I noticed that I cannot export vector maps in PNG format using
`d.vect` and Cairo as the driver. There is no problem in exporting
vector maps in the BMP and PDF formats. Raster maps export just fine.
Any hints where the issue can be?
Thank you, Nikos
