[GRASS-dev] [GRASS GIS] #3884: items selected on drop-down controls not inserted into GRASS command
trac at osgeo.org
Tue Feb 18 11:42:38 PST 2020
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.6.2
Component: wxGUI | Version: svn-releasebranch76
Resolution: | Keywords: wxGUI control
CPU: Unspecified | Platform: Unspecified
Comment (by nila):
I can confirm this is still an issue for macOS on master (7.9) and I have
been wrestling with this for some quite some time with GRASS7 (can't
remember exactly). It seems to me be a binding issue (maybe for mac
only?).
This is basically the same description for the issue as cmbarton, sorry
'bout that, but this is how I would describe it:
Clicking and selecting with the popup menu for Location it inserts the
selected location. But doesn't trigger selection updated method. Editing
the text field manually after selection (e.g. deleting the last letter and
rewrite it or inserting a space and delete it – well, you get the picture)
do trigger the update selection method and you can proceed. The same
procedure must be repeated with mapset. Finally, for some reason,
selecting the map with the popup menu works as intended.
I'm pretty new to the GRASS code base, I couldn't even find where to look
into this issue. Any suggestion?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3884#comment:1>
