[GRASS-dev] missing logs for Windows addons
Anna Petrášová
kratochanna at gmail.com
Thu Jan 2 11:08:09 PST 2020
This is still an issue, in case of 7.8.1 it can't find numpy, e.g.
https://wingrass.fsv.cvut.cz/grass78/x86_64/addons/grass-7.8.1/logs/r.futures.log
in case of 7.8.dev and 7.9 everything fails due to:
Fatal Python error: initfsencoding: unable to load the file system codec
File "C:/OSGeo4W64/apps/Python27\lib\encodings\__init__.py", line 123
raise CodecRegistryError,\
SyntaxError: invalid syntax
which seems to be some python 2/3 mismatch, e.g.:
https://trac.osgeo.org/osgeo4w/ticket/547
On Mon, Nov 25, 2019 at 7:59 PM Stefan Blumentrath <
Stefan.Blumentrath at nina.no> wrote:
> Seems modules that import numpy fail to build....
> *Fra:* grass-dev <grass-dev-bounces at lists.osgeo.org> på vegne av Martin
> Landa <landa.martin at gmail.com>
> *Sendt:* mandag 25. november 2019 18:34
> *Til:* Anna Petrášová <kratochanna at gmail.com>
> *Kopi:* GRASS-dev <grass-dev at lists.osgeo.org>
> *Emne:* Re: [GRASS-dev] missing logs for Windows addons
> po 25. 11. 2019 v 18:32 odesílatel Martin Landa <landa.martin at gmail.com>
> napsal:
> > logs are available [1]. Apparently broken, I will take a look ASAP.
> BTW, logs for 7.8.1 looks better ;-)
> Ma
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
> grass-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20200102/9cbfe942/attachment.html>
