[GRASS-dev] [GRASS GIS] #2499: v.in.ogr in does not handle "nan" in attribute tables properly
GRASS GIS trac at osgeo.org
Sun Jan 5 13:01:38 PST 2020
  Reporter:  sbl          |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.8.3
 Component:  Vector       |    Version:  unspecified
Resolution:               |   Keywords:  v.in.ogr, DBMI, SQLite, nan
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mmetz):
 This is not a problem of v.in.ogr, but of SQLite, and possibly other GRASS
 db drivers.
 A solution would be to change all GRASS modules that update attribute
 tables and replace nan/-nan with NULL.
 Another solution would be to replace nan/-nan with NULL in
 db_execute_immediate() which is probably easier than changing all modules
 but might have unexpected side effects because SQL statements passed to
 the db drivers can be quite complex.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2499#comment:9>
