[GRASS-dev] missing logs for Windows addons
Anna Petrášová
kratochanna at gmail.com
Mon Jan 6 00:42:44 PST 2020
Thanks for looking into this! Unfortunately, there is now a different
problem, in 7.8 and 7.9, it looks like all c modules are not compiled,
that's also the case of r.futures.pga (which is a c module within
r.futures):
make -C r.futures.pga || echo
/c/msys64/usr/src/grass-addons/grass7/raster/r.futures/r.futures.pga
>> /usr/src/grass782/error.log
make[1]: Entering directory
'/c/msys64/usr/src/grass-addons/grass7/raster/r.futures/r.futures.pga'
test -d OBJ.x86_64-w64-mingw32 || mkdir -p OBJ.x86_64-w64-mingw32
gcc -I/c/OSGeo4W64/include -g -O2 -I/c/OSGeo4W64/include
-I/usr/src/grass782/dist.x86_64-w64-mingw32/include
-D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\"
-DRELDIR=\"/c/msys64/usr/src/grass-addons/grass7/raster/r.futures/r.futures.pga\"
-o OBJ.x86_64-w64-mingw32/keyvalue.o -c keyvalue.c
/bin/sh: gcc: command not found
make[1]: *** [/c/msys64/usr/src/grass782/include/Make/Compile.make:32:
OBJ.x86_64-w64-mingw32/keyvalue.o] Error 127
On Fri, Jan 3, 2020 at 3:13 PM Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> čt 2. 1. 2020 v 20:08 odesílatel Anna Petrášová <kratochanna at gmail.com>
> napsal:
> > This is still an issue, in case of 7.8.1 it can't find numpy, e.g.
> https://wingrass.fsv.cvut.cz/grass78/x86_64/addons/grass-7.8.1/logs/r.futures.log
> fixed [1].
> > in case of 7.8.dev and 7.9 everything fails due to:
> Should be better [2], r.futures compiled [3]. Ma
> [1]
> [2] https://wingrass.fsv.cvut.cz/grass79/x86_64/addons/grass-7.9.dev/logs/
> [3]
> https://wingrass.fsv.cvut.cz/grass79/x86_64/addons/grass-7.9.dev/logs/r.futures.log
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20200106/fc541703/attachment.html>
