[GRASS-dev] missing logs for Windows addons
Moritz Lennert mlennert at club.worldonline.be
Mon Jan 6 07:56:12 PST 2020
On 6/01/20 13:29, Martin Landa wrote:
> Ahoj,
> po 6. 1. 2020 v 9:42 odesílatel Anna Petrášová <kratochanna at gmail.com> napsal:
>> Thanks for looking into this! Unfortunately, there is now a different problem, in 7.8 and 7.9, it looks like all c modules are not compiled, that's also the case of r.futures.pga (which is a c module within r.futures):
> ops, opraveno. Martin
I see that r.object.activelearning also fails with:
"ModuleNotFoundError: No module named 'scipy'"
Should this module be changed somehow to wrap the import in a way to
only make it fail at runtime ? ISTR, there was a technique for that, or ?
Moritz
