[GRASS-dev] [GRASS GIS] #4017: run addon failed > name 'unicode' is not defined
trac at osgeo.org
Sat Jan 11 10:16:09 PST 2020
Reporter: 1266 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: git-releasebranch78
Keywords: | CPU: x86-64
Platform: Linux |
After installing grass 7.8.3 on debian buster my python2 scripts does not
work anymore. Error message :
File "/usr/local/grass78/gui/wxpython/gui_core/forms.py",
line 2866, in ParseCommand
blackList=_blackList)
File "/usr/local/grass78/etc/python/grass/script/task.py",
line 522, in parse_interface
tree = etree.fromstring(get_interface_description(name))
line 498, in get_interface_description
"\n\nDetails: <{det}>").format(cmd=cmd, det=decode(cmderr)))
grass.exceptions
ScriptError
Unable to fetch interface description for command
'<r.wtg.visibility>'.
Details: <Traceback (most recent call last):
File
"/home/frank/.grass7/addons/scripts/r.wtg.visibility", line
299, in <module>
from grass.pygrass.utils import set_path
File
"/usr/local/grass78/etc/python/grass/pygrass/utils.py", line
7, in <module>
import grass.lib.gis as libgis
File "/usr/local/grass78/etc/python/grass/lib/gis.py",
line 4
SyntaxError: Non-ASCII character '\xc3' in file
/usr/local/grass78/etc/python/grass/lib/gis.py on line 5,
but no encoding declared; see
http://python.org/dev/peps/pep-0263/ for details
During handling of the above exception, another exception
occurred:
File "/usr/local/grass78/gui/wxpython/core/gconsole.py",
line 493, in RunCmd
task = GUI(show=None).ParseCommand(command)
line 2868, in ParseCommand
raise gcmd.GException(e.value)
core.gcmd
GException
File
299, in <module>
File
7, in <module>
line 4
occurred:
File "/usr/local/grass78/gui/wxpython/gui_core/prompt.py",
line 413, in OnKeyPressed
self._runCmd(self.GetCurLine()[0].strip())
line 120, in _runCmd
self.promptRunCmd.emit(cmd=cmd)
File
"/usr/local/grass78/etc/python/grass/pydispatch/signal.py",
line 229, in emit
dispatcher.send(signal=self, *args, **kwargs)
File "/usr/local/grass78/etc/python/grass/pydispatch/dispa
tcher.py", line 349, in send
**named
File "/usr/local/grass78/etc/python/grass/pydispatch/robus
tapply.py", line 60, in robustApply
return receiver(*arguments, **named)
File
"/usr/local/grass78/gui/wxpython/gui_core/goutput.py", line
120, in <lambda>
self._gconsole.RunCmd(command=cmd))
line 496, in RunCmd
message=unicode(e),
NameError
If I add # -*- coding:UTF-8 -*- on first line in
/usr/local/grass78/etc/python/grass/lib/gis.py and
/usr/local/grass78/etc/python/grass/lib/raster.py my scripts seem to work
(gui dispalyed)
my LOCAL is LANG=fr_FR.UTF-8
Ticket URL: <https://trac.osgeo.org/grass/ticket/4017>
