[GRASS-dev] Does it exist a fast way to know the type of raster without using r.info
Taïs tgrippa at ulb.ac.be
Mon Jan 13 06:13:04 PST 2020
Hi all,
The add-on r.zonal.classes uses r.info to check if the provided rasters
are in CELL because r.stats require a CELL raster as input.
The problem is that for heavy raster, running r.info takes ages compared
to r.stats and thus create a bottleneck.
I'm looking for another to get the info about the type of raster (CELL,
FCELL,...) which will be much faster. Some of you have any idea ?
Thanks
-------------- section suivante --------------
Une pièce jointe autre que texte a été nettoyée...
Nom: tgrippa.vcf
Type: text/x-vcard
Taille: 4 octets
Desc: non disponible
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20200113/e8a5d9e7/attachment.vcf>
