[GRASS-dev] [GRASS GIS] #3883: GRASS master does not compile with Python 3 on Mac
trac at osgeo.org
Tue Jan 21 07:51:53 PST 2020
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.8.3
Component: Default | Version: svn-trunk
Resolution: | Keywords:
CPU: Unspecified | Platform: MacOSX
Comment (by guano):
I'm facing similar issues. Compiling on OSX 10.14 Mojave, with python
3.7.4 (pyenv). I'm not using the Mac SDK, just the Mac Command Line Tools.
Compilation breaks with this error:
Errors in:
/Volumes/MacintoshHD2/grass/lib/python/ctypes
/Volumes/MacintoshHD2/grass/raster/r.in.lidar
/Volumes/MacintoshHD2/grass/raster3d/r3.in.lidar
/Volumes/MacintoshHD2/grass/vector/v.out.lidar
/Volumes/MacintoshHD2/grass/vector/v.in.lidar
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Tue Jan 21 12:42:28 -03 2020
make: *** [default] Error 1
So I cd into ctypes and run make:
File "./ctypesgen.py", line 162, in <module>
descriptions = ctypesgencore.parser.parse(options.headers, options)
File
"/Volumes/MacintoshHD2/grass/lib/python/ctypes/ctypesgencore/parser/__init__.py",
line 22, in parse
parser.parse()
File
"/Volumes/MacintoshHD2/grass/lib/python/ctypes/ctypesgencore/parser/datacollectingparser.py",
line 74, in parse
ctypesparser.CtypesParser.parse(self, fname, False)
File
"/Volumes/MacintoshHD2/grass/lib/python/ctypes/ctypesgencore/parser/cparser.py",
line 122, in parse
self.preprocessor_parser.parse(filename)
File
"/Volumes/MacintoshHD2/grass/lib/python/ctypes/ctypesgencore/parser/preprocessor.py",
line 173, in parse
ppout, pperr = pp.communicate()
File "/Users/guano/.pyenv/versions/3.7.4/lib/python3.7/subprocess.py",
line 939, in communicate
stdout, stderr = self._communicate(input, endtime, timeout)
line 1721, in _communicate
self.stdout.errors)
line 816, in _translate_newlines
data = data.decode(encoding, errors)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xa9 in position
1400362: invalid start byte
make[1]: *** [OBJ.x86_64-apple-darwin18.7.0/nviz.py] Error 1
make: *** [default] Error 2
So is this NVIZ-related?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3883#comment:9>
