[GRASS-dev] missing logs for Windows addons
Anna Petrášová
kratochanna at gmail.com
Fri Jan 24 07:16:01 PST 2020
Hi, coming back to this... the addons don't seem to be updated, I checked 2
addons and no recent changes are incorporated in the zip files. Is it
possible you still download it from trac rather than github?
Thanks!
On Mon, Jan 6, 2020 at 12:10 PM Ondřej Pešek <pesej.ondrek at gmail.com> wrote:
> Hi Moritz,
> po 6. 1. 2020 v 16:56 odesílatel Moritz Lennert <
> mlennert at club.worldonline.be> napsal:
>> I see that r.object.activelearning also fails with:
>> "ModuleNotFoundError: No module named 'scipy'"
>> Should this module be changed somehow to wrap the import in a way to
>> only make it fail at runtime ? ISTR, there was a technique for that, or ?
> A lazy import should do this for you.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20200124/f584e77d/attachment.html>
