[GRASS-dev] r.slope.aspect with -n flag giving aspect of flat areas as -9998
Anna Petrášová kratochanna at gmail.com
Wed Jan 29 20:23:39 PST 2020
Yes, please create an issue on github:
https://github.com/OSGeo/grass/issues/new/choose
On Tue, Jan 28, 2020 at 6:49 AM Pedro Venâncio <pedrongvenancio at gmail.com>
wrote:
> Hi all,
> I was testing r.slope.aspect with the "new" -n flag, also to include -e
> and -n flags in QGIS Processing, but -n flag is giving aspect values of
> flat areas as -9998, instead of -9999, when the precision choosed is CELL,
> and the output data type is CELL.
> https://grass.osgeo.org/grass78/manuals/r.slope.aspect.html
> I've tested with GRASS 7.6 (on Linux) and GRASS 7.8.2 (on Windows), both
> in the GUI and CLI.
> (Tue Jan 28 11:19:40 2020)
> r.slope.aspect -e -n --verbose elevation=SRTM_PT_25m at PERMANENT
> slope=SRTM_PT_25m_Slope_Deg_GRASS aspect=SRTM_PT_25m_Aspect_Std_GRASS
> precision=CELL
> Percent complete...
> Elevation products for mapset <PERMANENT> in <SRTM_PT_25m>
> Min computed aspect 0.0000, max computed aspect 360.0000
> Aspect raster map <SRTM_PT_25m_Aspect_Std_GRASS> complete
> Min computed slope 0.0000, max computed slope 75.2970
> Slope raster map <SRTM_PT_25m_Slope_Deg_GRASS> complete
> (Tue Jan 28 11:20:24 2020) Comando terminado (43 sec)
> r.info map=SRTM_PT_25m_Aspect_Std_GRASS at PERMANENT
>  | Map:      SRTM_PT_25m_Aspect_Std_GRASS@  Date: Tue Jan 28 11:20:24
> 2020    |
>  | Mapset:   PERMANENT                      Login of Creator:
> PedroVenancio   |
>  | Location: SRTM_PT_25m
>  | DataBase: D:\ICNF\Modelos_Combustivel_2018\Landscape_File\grass78
>  | Title:    Aspect counterclockwise in degrees from east
>  | Timestamp: none
>  |   Type of Map:  raster               Number of Categories: 360
>  |   Data Type:    CELL
>  |   Rows:         23200
>  |   Columns:      11360
>  |   Total Cells:  263552000
>  |        Projection: ETRS89 / Portugal TM06
>  |            N:     278000    S:    -302000   Res:    25
>  |            E:     164000    W:    -120000   Res:    25
>  |   Range of data:    min = -9998  max = 360
>  |   Data Source:
>  |    raster elevation file SRTM_PT_25m at PERMANENT
>  |   Data Description:
>  |    generated by r.slope.aspect
>  |   Comments:
>  |    aspect map elev = SRTM_PT_25m at PERMANENT
>  |    zfactor = 1.00
>  |    min_slope = 0.000000
>  |    r.slope.aspect --verbose -e -n elevation="SRTM_PT_25m at PERMANENT"
> slo\   |
>  |    pe="SRTM_PT_25m_Slope_Deg_GRASS"
> aspect="SRTM_PT_25m_Aspect_Std_GRAS\   |
>  |    S" format="degrees" precision="CELL" zscale=1.0 min_slope=0.0
> (Tue Jan 28 11:26:09 2020) Comando terminado (0 sec)
> Using the default precision as FCELL, all goes ok:
> (Tue Jan 28 11:33:08 2020)
> slope=SRTM_PT_25m_Slope_Deg_GRASS_2 aspect=SRTM_PT_25m_Aspect_Std_GRASS_2
> Percent complete...
> Min computed aspect 0.0000, max computed aspect 359.8096
> Aspect raster map <SRTM_PT_25m_Aspect_Std_GRASS_2> complete
> Slope raster map <SRTM_PT_25m_Slope_Deg_GRASS_2> complete
> (Tue Jan 28 11:34:01 2020) Comando terminado (53 sec)
> (Tue Jan 28 11:34:27 2020)
> r.info map=SRTM_PT_25m_Aspect_Std_GRASS_2 at PERMANENT
>  | Map:      SRTM_PT_25m_Aspect_Std_GRASS_  Date: Tue Jan 28 11:34:01 2020
> PedroVenancio   |
>  | Timestamp: none
>  |   Data Type:    FCELL
>  |   Rows:         23200
>  |   Columns:      11360
>  |   Range of data:    min = -9999  max = 359.8097
>  |   Data Source:
>  |   Data Description:
>  |   Comments:
>  |    zfactor = 1.00
> slo\   |
>  |    pe="SRTM_PT_25m_Slope_Deg_GRASS_2"
> aspect="SRTM_PT_25m_Aspect_Std_GR\   |
>  |    ASS_2" format="degrees" precision="FCELL" zscale=1.0 min_slope=0.0
> (Tue Jan 28 11:34:28 2020) Comando terminado (0 sec)
> The elevation map I'm using is this one:
> https://www.fc.up.pt/pessoas/jagoncal/srtm/SRTM_PT_25m.tif
> As CELL is a 32 bit integer with a range from -2,147,483,647 to
> +2,147,483,647, -9999 should be fine to conform inside it.
> Another issue I see is in r.info, that is showing the title as
> which is not correct in this case, as the -n flag was used.
> Could these be bugs?
> Thank you very much.
> Best regards,
> Pedro Venâncio
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20200129/80cd638a/attachment-0001.html>
